Question about Vacuums
What needles for a Singer Industrial 95K60 sewing machine
SOURCE: With my K6 Industrial Singer
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Posted on Feb 03, 2009
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
  • 78 Answers
SOURCE: Unable to locate needles for Singer Ultralock
try singer needles 2054 you should be able to find them on line or at a local sewing store
Posted on Jul 01, 2010
  • 381 Answers
SOURCE: How to adjust belt tension
When you say 'Vintage'-- how old are we talking about?
Please describe the belt...
Is this an old Pedal (or platform that you rock your feet, to make the drive pulley go around)
Is it a 'pedal' powered machine?-- one with a round leather belt?
If it is the latter--
Is that belt all dried out?-- or is it still supple and still providing a good surface to grip the grooves of the 2 pulleys?
Tell us more-- maybe we can help.
Mack B
Posted on Jan 10, 2011
  • 517 Answers
SOURCE: sears kenmore 158.321 sewing machine
Good day!!!
If the problem is always broke the needle..
The problem could be the correct timing of the machine please adjust the timing of your sewing machine to fix your problem...
Thank you and good luck..
Posted on Jun 24, 2011
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
My needle hits / bottoms out on the bobbin holder and hook assembly. Do do I need to fix timing
there are several things that may cause this situation.
the needle may not be seated all the way up where it is supposed to be.
here is a site that may give you more insight.
How can fix the needle hitting the bobbin case on my sewing machine
Mar 05, 2015 | Singer 8763 Curvy Computerized Sewing...
HOW TO INSTALL NEEDLE PLATE ON SINGER 30518 SEWING MACHINE?
Hey, i just took the needle plate out to clean and i cant put it back. same model 30518, somebody can help? :(
Oct 27, 2014 | SewShop.com Singer Model 30518 Instruction...
What is my needle hitting that breaks it on my singer sewing machine 247
sounds like the machine is out of time . best solution is to take it in to be repaired .
Oct 11, 2014 | Singer Tension Assembly, Fits: Models 242,...
Why is my sewing machine skipping stitches
If the needle is slightly bent it won't pick up the lower thread all the time. Try using a new needle.
Sep 26, 2012 | Singer 7256 Fashion Mate Sewing Machine
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
How to adjust belt tension on vintage Singer industrial sewing machine
Mack B
Jan 10, 2011 | Singer Vacuums
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
