Question about Sport & Outdoor - Others
1989 baja 226 sport boat will not stay running. Just replaced fuel pump.
  • 141 Answers
SOURCE: 1989 cougar wont start
Is the inertia switch on the passenger kick panel popped?
Posted on Jan 09, 2009
  • 75 Answers
SOURCE: fuel pump 1989 jeep cherokee
should be just under the rear drivers side door.
Posted on Oct 31, 2009
agent91
  • 2100 Answers
SOURCE: fuel pump ducati 750 sport 2002 runs at times, but mostly not
Your fuel pump is vacuum operated, I would look for a crack in the rubber somewhere. Also, the side stand, the bike will start with it down, but will shut off the second you put it in gear. I have a 2002 S4.
Posted on Feb 15, 2010
Testimonial: "sidest. switch OK. Short wiring pump doesn't make it run! Emptied tank, found a loose part with o-ring seal on the bottom. Dealer tomorrow "
  • 474 Answers
SOURCE: my 1989 s10 blazer wont idle
Check for plugged ctalitic converter
Posted on Jul 23, 2010
marc8163
  • 135 Answers
SOURCE: 1989 buick century 3.3 car starts idles but wont run when giving gas it acts like running out of fuel but fuel pump stay running and has pressure new fuel filter spray carb cleaner it will stay runnin
have you put a fuel pressure gauge on it if so how many ponds of pressure does it have also if this is a distributerless car turn engine with a socket see if there is slack in rotation if you turn counter clockwise 1/4 turn stop and turn clockwise if so you more than likely have a stretched timing chain or jumped time
Posted on Apr 01, 2012
1989 Evinrude 15 hp E15RCEC Outboard Motor starts but won't stay running. what could be the problem Tried to clean carburetor, didn't work.
depending on how often you used the engine
problems include :-
dirt ,corrosion, rubber bits in the carby---fix is to have the carby professionally cleaned and overhauled
rubber from the fuel hoses disintergrating and causing problems in the carby, the pump valves
the rubber diaphragm in the pump is failing and not producing enough fuel to keep the motor running
the vent on the cap of the fuel tank is still closed creating a vacuum in the fuel system
it would be a good idea to replace all rubber hoses from the tank to the carby, overhaul the fuel pump, and have the carby professionally cleaned and overhauled
if you pull off any rubber hose and get a black stain on your hand ,that is rubber failing.
Aug 22, 2015 | Boating
1995 trans sport van new fuel pump, won't start
If the pump continued to run after shutting off the car you fuel pump relay was probably staying latched. I would replace the relay as well based on your info. Along with the pump the fuel filter should be replaced too and fuel pressure should be checked. Make sure your ground is good also.
Apr 13, 2014 | 1994 Pontiac Trans Sport
1989 f250 460 engine fuel problem
if the fuel lines have any rubber fuel lines they could be sucking air. also try replacing the fuel caps, it may not be venting
Dec 02, 2013 | 1989 Ford F 250
94 200 hp evinrude ocean pro 20ft hydra sport. Can't get on a plane runs top end at 4000rpm at 23mph. New fuel pump. Replaced all filters cyl are fine and has good comp. Need help Thanks
Sounds like you have a serious drag or weight issue on the boat.
Could also be the wrong propeller for the setup.
If that is not it try cleaning carbs with seafoam and adding seafoam to fuel.
Sep 05, 2013 | RTO Oar Sockets
1984 suzuki DT60 outboard set up for 5 yrs cleaned carbs got it running. wont stay running unless you pump the primer bulb. does it need a fuel pump?
yes. OR you have an air leak in the fuel system. Easy way to tell is with a clear fuel line between the fuel pump and the carb. If you see bubbles, you are looking at a new fuel line connector or aire leak at the fuel pump. If you pump up pressure with out the motor running A fault may leak gas.
Jul 09, 2012 | Light Outboard Motor Boat Bass Fishing...
01 ford explorer sport won't stay running. turns over fine and starts but quits right away
Check for vacuum leak at intake manifold or bad fuel pump relay or have fuel pressure checked to see if fuel pump is working properly 40-45 psi it should be pumping
Dec 18, 2011 | 2001 Ford Explorer Sport
I have 1989 corsica 4cyl runs for 2or 3 sec. i put fuel pump on fuel filter an mogel on behind coil pack.it will run if you put little gas in at a time . fuel pump will spra for a bit then stops . put map...
the fuel pump circut will prime for 2 or 3 seconds when you first turn on the key then stops until you crank it the circut has to see rpms to continue the pump voltage i would see if the pump works when cranking check for injector pulse
Jan 14, 2011 | 1989 Chevrolet Corsica
I have 1989 f-150 4.9l 6 cly engine. The fuel pump shuts off.
check the emergency fuel shut off switch it may be half set it is on the firewall by the clutch pedal reset it if that does not work it is a relay or a short in the pump it is not pushing enough pressure to keep it running
Dec 22, 2008 | 1989 Ford F 150
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
