Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
HP office jet 8500: replaced black cartridge and pressed * for 5 seconds. light still flashes that cartidge needs to be replaced. will not print.
  • 1,218 Answers
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Oct 12, 2010
Office jet 8500 wireless all in one inkjet printer
Most ink jet printers will not print if any cartridge is empty even if you are only printing black. The printer goes through the initialization but never goes on line. The only way to get the unit to print will be to install a full cartridge so the printer will pass the config tests. There is no way to bypass this function, sorry
Apr 02, 2013 | HP Officejet 6500 Wireless All-in-One...
In my printer hp 1600c always cartidge light is flashing but all the cartidge is inserted properly.
in that case you will have to reset the printer;
Follow the procedures below to successfully reset your printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the printer.
3. Wait for the "Insert Cartridge" message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Good luck.
Nov 30, 2010 | HP DeskJet 1600C InkJet Printer
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Black ink cartridge is full, but it does not print
It is more likely that you have a bad or damaged Smart Chip on your Black ink cartridge. Check out this site, it may be helpful adaptiveink.com
Jul 27, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Where can i find hp office jet 8500 print heads
Try staples or home depot if they are still open otherwise you have to order it from HP or you could try the new egghead. HP's address is www.hp.com
Mar 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp f4288 all in one black cartridge( N0.818) refilling method
when i fill this cartidge after finishing the cartidge is not printing why?
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
