Question about Sony KDL46Z5100 46 in. HDTV LCD
My sony bravia model kdl-46z5100 lcd turns off and on while watching my programs. Call sony and they sent a tech out twice and still shutts off and turn back on. Please help.
xCAUSALITYx
  • 210 Answers
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Posted on Oct 09, 2009
cene765
  • 787 Answers
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Posted on Nov 23, 2009
SOURCE: Replacing LCD TV screen
crack on the screan of 32 inch plasma
Posted on Dec 04, 2009
  • 51 Answers
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Posted on Dec 15, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Blank screen
The fault is with its main power supply regulator section itself. One or more voltage rail is missing. Your TV need a through checkup. Seek tech assistance.
Jun 06, 2012 | Sony Bravia KDL-40V4150 40 in. LCD HDTV
How to reset my sony xbr9 to factory setting?
I sent a premium offer to solve tv issue but got no response so far, not sure why.
I'm Sony tech and can be helpful to resolve this problem.
Aug 24, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony bravia needs a new remote, have bought a
go on line to sony they will send new one at cost
Jun 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The standby button is flashing twice- sony bravia klv-40v550a
Unplug the power cord for 30 min, plug back in and turn on.
Should ths not work seek repair or replacement
Apr 10, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We lose audio on our Sony BRAVIA KDL-52W4100
This problem appears to be an issue with numerous Sony Bravia owners of the same model. Although still seeking a soulution, it would appear that our cable provider (Verizon) has replaced all of their components and the Geek Squad from Best Buy where we purchased the unit, points the finger at Verizon. None of our other Fios-equipped TV's exhibit this problem so I am glad we bought the service plan with the TV and will continue to seek a remedy.
Mar 04, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We were watching tv on our Sony Bravia - KDL-W3000 LCD tv and the screen turned pink. We can still hear the show's but the entire screen is pink. Any idea why?
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Jan 01, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony KDL46Z5100 46 in. HDTV LCD Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
