Question about Maytag Refrigerators
I have a Maytag refrigerator with the freezer on top. I bought it new in 1995. It is empty and runs all the time, as far as I know. The top and upper sides are very warm. Is this normal or is this a fire hazard?
  • kdcavanaugh Sep 07, 2010
    Dear Rockitman187, Thank you for answering about my refrigerator. Is it also normal for it to run all the time just because its empty? Thank you very much kdcavanaugh
    President:
  • 1,932 Answers
The wall get warmer is normal it is not a fire hazard.As the compressor runs the wall becomes warmer.
Thank You
Posted on Sep 08, 2010
    President:
  • 2,559 Answers
It is very normal for the outside of the unit to be warm, The inside shoulld never be though.
Posted on Sep 06, 2010
  • Randy Hough
    Randy Hough Sep 15, 2010
    No, it should not run all the time, it should only run until it reaches the proper temp inside.
Maytag Refrigerator, Vibrating Noise
What is a short time? 5 or 6 secondswould be icemaker fill valve.Tubing in back is a common noise maker ,could be somthing hitting the condenser fan blade.
Nov 27, 2012 | Maytag MSD2434GE Side by Side Refrigerator
Freezer is working fine including the ice maker but the refrigerator is warm. The vent at the top of the refrigerator is open but no air comming through. I beleve that it must be a fan but I seam to locate...
As far as my knowledge I know that this freezer is using insulation in the door for putting out warm air and keeping cool air inside. Your refigrators insulator has gone bad. You yourself cannot assess it without proper device and you will also require a new insulator to replace the bad one. My suggestion to you is to kindly let me know how old your refigrator is and how far you can go with repairing it.
Jun 08, 2011 | Maytag 24.8 Cu. Ft. Side-by-Side...
Brand new maytag 25 cu.ft side by side ref./freezer cycless on about every 12 to 18 mins and runs for averge 9 mins. two senior citizens no children in house ergo doors are not opened and closed...
The fact that you do not have much stuff in there is actually causing it to run more....and actually those run times are not all that bad....the refrigeration units are not nearly as large as they used to be in the past... Get more stuff inside and it will actually run less...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 20, 2010 | Maytag MSD2572VEW (25 cu ft) Side by Side...
My ice maker is not working I put in a new one it will not fill up, or empty if i put water in it, also my icecream stys soft it will not freeze,I clean the compresser and the coils behine the fan but it...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 15, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Maytag Bottom Freezer not working
Maybe fan in freezer not running to circulate air.
Aug 28, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
MAYTAG MTB2156GE REFRIGERATOR. NOT GETTING COLD. THE FAN IN THE BACK OF THE FREEZER COMPARTMENT DOES NOT WORK. EMPTIED FRIG AND SHUT IT OFF. NOW THERE IS WATER ON THE FLOOR. DOES THIS HAVE SOMETHING TO DO...
Whatever you do do not run the refrigerator with the freezer fan not working. That Fan is about $70.00 depending who you get it from and easy to change. If you could find someone we could do it without calling service, that is what we are here for. See if you can find someone with a digital meter and let me know when ready, Sea Breeze
Feb 17, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
Sep 05, 2009 | Maytag Refrigerators
MSD2756GEB (Side By Side) Runs All the time
I went to the Maytag site and found a similar QA area and found a short article that talked about frost build up and/or blockage of any sort preventing airflow from the freezer compartment to the refrigerator compartment. They said this would impact proper operation of the refrigerator.
I emptied out the freezer after I inspected and found significant frost/ice in the upper right hand corner around the "scoop" that directs airflow into the refrigerator compartment. I took that off and removed all the ice build up (almost 1/2 blockage). I then removed the entire back panel and noticed that my refrigeration unit was completely iced up with significant build up around all the wires and thermostat.
I defrosted the entire unit with the aid of a hairdryer (at a safe distance so not to over heat anything) and then made sure my evaporator coils were all clean in the back and turned the refrigerator back on. (I unplugged it during the defrost operation.) I made sure that the fans worked both above the interior refrigeration unit and at the evaporator unit. Then I waited for the compressor to kick on.
Wallah! Everything so far was working so I put the rear panel back together in the freezer section, closed her up and waited to see what would happen. So far I've had to turn down the refrigerator section to around 5 and the freezer to about 4. The unit now seems to run correctly, shutting off after it runs for a while.
So I guess I'll wait and see how long this defrosting step works. Maybe the self defrost switch or something is not working and the problem will return in a month or so. We'll see..............
Feb 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator ,freezer and bottom not getting cold
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The compressor is running ,but fan in top not running . The heater in top check good,also defrost thermostat is good and you think defrost timer is OK.
There was some ice on the top coil when you first took the back cover off, so you though may be heater or defrost time, but they test OK as far as you know.
Did you check the pressure to see if the coolant is low?
This will cause icing if you need freon!
How old is the fridge?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
Sep 21, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
