Question about Vacuums
I have a hoover floor mate(the hard floor cleaner). The plastic solution cannister leaks through a spring plunger.
  • 1,673 Answers
There is a rubber bushing that should be in there also. But replacing your tank may be the best option.
Posted on May 13, 2008
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link:
As a special offer here is an exclusive 10% coupon for readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
How can I get a Manual for the Hoover H3000 Floor Mate Hard Floor Cleanere?
You can download it in a PDF form directly from the manufacturer's website:
You will require Adobe Reader in order to view the PDF document. If you do not have Adobe Reader, you can download it for free from Adobe's website:
Apr 02, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
I just bought a hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the brissles at all. Help please. It is brand new. any ideas???
I just bought a Hoover
Posted by serdmann4 on May 17, 2008
I just bought a Hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the bristles at all. Help please. It is brand new. Any ideas???
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Plastic parts breaking
none ! in most cases Hoover is the best. Whatever you do don't buy Bissel
Oct 13, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Water leaks
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Oct 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
74 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
