Question about Vacuums
Ice and water are developing in my almost emty refridgerator. How can I fix it?
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
How am I suppose to emty The uh70060I feel that I am not getting all the dirt out. Can the red top be removed?
Hi! It is not recommended you disassemble the red cyclonic filter. You may use your upholstery brush or something similar to brush off the cyclonic filter. You may also wipe it down with a damp cloth. Do not rinse or submerge the cyclonic filter in water. Hope this helps!
Jul 09, 2014 | Hoover UH70060 Bagless Upright Cyclonic...
My portable ice maker quit working. The water is not getting to the top ice maker part. The model # MCM30SST. The motor sounds like it is working.
If you have recently moved the fridge, you may have rolled the fridge on top of the water line. This would restrict the water flow to the regulator. If the water line is not pinched, then the regulator is bad. You can replace it for around $25 with a universal part, or pay $50 for the original.
Thank,
Jim
Aug 03, 2011 | Vacuums
The ice tray is freezing up . what can be done to fix this problem. I have a magic chef ice maker MCIM30SST
This answer came straight from the manufacture:
Stop the ice maker, and restart when the ice blocks melt. Select the
small ice size. Also Change the water in the reservoir.
Use water between 45 -90 F.
Not sure if that will do it but that is the only fix we could find straight from the manufacture. We wish you the best.
Mar 06, 2011 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Icemaker draining alot of water
if you mean that the water is not rurning off going into the ice maker then its likely a bad solonoid ... there are two such solonoids (one for water and one for ice) located usually at the bottom behind rthe refregerator .. they can be found where the water is hooked up to the refrigerator ... the electrically operated solonoids are valves that turn water on and off ... if they get deposits inside they may quit working .. replaceing them is usually not hard (make sure to unplug first) ...
Apr 15, 2010 | Vacuums
My bissel has a upolsty cleaner on it, I used it to clean my couch then shut it off to emty then went to clean the other couch now it wont spray cleaner or ****? can anyone help me?
things to look at...
  • Tank is properly seated (remove and reinstall)
  • Tools are selected (not floors)
  • ensure the handle is in the full upright position
If these don't correct the problem let me know, if this does correct the problem, please take the time to give this solution a fix ya rating.
clarkco
Mar 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Scooba runs for a short time then the service light comes on
have you emtied it and cleaned it good.take the battery out and let it stand for 30 minutes then try again
Feb 22, 2009 | iRobot 5800 Scooba Vacuum
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to hoover.com to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
