Question about Frigidaire FEQ1442ES Electric Dryer
Frigidaire fefb9200es0 does not heat - Frigidaire FEQ1442ES Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
WHERE IS THE HEATING ELEMENT FOR A FRIGIDAIRE FER341ACO
it is located on the back inside of the dryer, here is a step by step:
http://www.ehow.com/how_4866523_fix-frigidaire-dryer-heating-elements.html
I do not know why you want to replace the element but if the problem is no heat then here is another website that can help,Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 19, 2011 | Frigidaire Electric Dryer
Frigidaire electric range oven wont heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 18, 2010 | Frigidaire Kitchen Ranges
heatman101
Sep 06, 2010 | Frigidaire Dryers
I have a gas Frigidaire dryer that heats once or twice
your cycling/hi-limit switch needs to be replaced,it is located on the outside of the burner tube to avoid an overheat condition and cycle the flame according to your heat setting on the control panel
Mar 14, 2010 | Frigidaire GLGQ332A Gas Dryer
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Frigidaire FEFB9200ES0 not draining water
H taello.You probably have to clean the filter.On the bottom of the front of the machine there are three screws.They are philips head.When you remove these screws the panel below the door will slide off.It's really easy so don't be nervous.Then if you look to the right side you will see a round 3 inch face with a handle grip built into it.They normally have a black magic marker mark on it.This tells you where to tighten it to when you put it back on.When you turn it counter clockwise it will undo.Then you pull it outwards and you will see all the stuff plugging it up.Clean it out and put it back in.This may have to be done on a regular basis.Then your machine will drain properly.Hope this helps.
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
127 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
