Question about Dryers
My Maytag electric dryer runs the cycle, but the clothes are not all dry. Trying to avoid expensive repair. Is there something I can do myself?
    Problem Solver:
First place to start is the dryer vent. Is it clogged where it leaves the machine or even furhter down. A clogged vent will dramatically reduce the efficiency of your dryer to the point where it may not dry clothes at all.
Posted on May 13, 2008
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Spins but no heat
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Noisy dryer with long dry time
check to see if the fans are loose if so replace them this will also cause poor drying time.iI find its better to dismanttle these dryers and check the rollers,belt and jockey pulley at the same time.they look hard to work on but they are easy just take you time theres generally no wires to undo.
Mar 21, 2008 | Asko T700 Electric Commercial Dryer
Dryer noise
open the door and if u can lift the drum up or down more than an inch the drum bearings are worn out. big job to repair unless under warranty.
Feb 07, 2008 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
