Question about Oreck XL M900A Upright WetDry Vacuum
I have an oreck xl shield scrubber and cannot remove the water tank. help
Make certain the yellow retaining latch is DOWN. Sometimes it LOOKS like it is all the way down when it isn't. Chances are, the tanks outlets were not properly greased, causing an o-ring to stick or roll off the seat.
Simply push down on the tank HARD at the top of the handle. You may have to strike it a few times but it will come off. It is best to do so in the upright position, rather than with the wheels extended. Once it is off, check the o-rings, re-seat if needed and apply some white grease to enhance the seal and prevent future sticking.
-Jeff
Oreck owner
Posted on Aug 13, 2012
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
b0sslady2001
  • 357 Answers
SOURCE: Oreck XL Vacuum
If you can find a Kirby G series vacuum lightbulb, it will work in the Oreck too!! Many sellers carry them online.
Posted on Apr 21, 2008
  • 172 Answers
SOURCE: I have to replace the motor brushes in my Oreck XL
If it's an AC induction motor there are no brushes.
Posted on Aug 12, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
Dirt devil spot scrubber not picking up
Hi there! There are a few reasons why your spot scrubber may not be picking up. Your dirty water tank may not be seated properly or the filter may be dirty Please try these steps.
1. Check the filter located on top of the dirty water tank. If dirty, rinse with water.
2. Check that the pour spout cap on dirty water tank is plugged.
3. Replace the dirty water tank. Make sure the dirty water tank is flush to the cleaner and seated properly.
4. Clean the nozzle of any hair or debris.
Hope this helps! For further assistance please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jul 03, 2014 | Dirt Devil SE2800 Spot Scrubber Handheld...
Trouble attaching nozzle to xl
Oreck is junk, despite the ads. trade it in on a Royal and yuu problems are over.
been in the vac repair business for 20 yrs
Jan 05, 2014 | Oreck XL Shield Power Scrubber Floor And...
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Removing and cleaning Oreck XL outer bag
how do i get the outher bag off of my oreck xl
Jan 16, 2012 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL picked up part of a bottle cap, then just started humming and wouldn't work. Help!
Remove the bottom and remove all screws at the bottom to gain access to the fan. You need to get the cap out for it is wedged into the fan attached to the motor
Jun 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oct 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL M900A Upright WetDry Vacuum Logo
159 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
