Question about Kenmore Refrigerators
Key pad of my Kenmore model 665.13482k900 dishwasher does not respond. Bimetal fuse is not blown and a test at point P1 to P6 on the control boards reads 120VAC. Any ideas?
  • 1314 Answers
SOURCE: lock out flashing
press and hold the air dry button for 4 seconds see if it dont turn the child lock off refer to your use and care guide
Posted on May 26, 2008
  • 110 Answers
SOURCE: Defrost heater not cycling
sound like to me you have a wire terminal short on the neutral side between you def. t-stat and the adc
go to www.servicematters.com for the service bulletin on this issue
Posted on Jun 01, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Kenmore elite dishwasher no power
1) Test the fuses blown or c.breaker reset.
2) See for any wires broken, burn, or loose wires repair.
3) test the switch door, if are open the starting relais will not move the motor see the diagram.
4)see the test that you can make
May 07, 2012 | Kenmore Dishwashers
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
BI METAL THERMAL CUT OFF SWITCH KEEPS BLOWING.
You might have debris clogging the drain/disposal. My wife just tried to wash labels off of some old jars, the paper is stuck in the drain and my TCO is blown.
Jun 04, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Sears model 665 ultra dishwasher has no power,breaker not blown but nothing works,no lights nothing
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 04, 2010 | Kenmore Dishwashers
Kenmore model 911 4238816 - the f7 code just came on beeping and we can't get it to stop. what is the error code mean, what can we do to stop it
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 03, 2010 | Kenmore Ovens
Model#665.15829000 kenmore
sounds like you have a stuck key pad on the touch control board. there is no easy way to check this, but you can unplug the "ribbon" strip from the control board. then you will need to jumper the board to see if you can force the unit to run by bypassing the key pad.
i cant find an exact match for your model number, but if you check the wiring diagram, behind the lower access panel, it will show you which 2 terminals can turn on a cycle.
the best thing i can tell you is to just replace the control panel with a touch pad assembly. it could cost about 125-150 bucks, but that should fix the problem.
Jan 30, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore dishwasher 665. No lights, tub not fullly drained.
check with a ohm meter should read 0 ohms or around 0
Dec 14, 2008 | Kenmore Dishwashers
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
