Question about BenQ PB7220 XGA DLP Projector Multimedia Projector
Laptop Lenovo R61 is connector to BenQ Projector. Problem is that Laptop desktop can not come up on the Projector. When pressing Fn+F7, desktop can not come op on the projector but error message "Computer 1/YrPbPr1, Source detect" and on the top left corner of the projector "Computer1/YrPbPr1, Auto, 1024x768 59 Hz, Presentation. And then black out on the projector.
SOURCE: BenQ 8700
I had a similar problem with my Benq 8700+. The aspect ratio would show in the R low corner on changinbg resolutions, and would close down to a single line ("anamorphic" for example) which would remain on the screen. I checked the manual (useless) and went through all the set up screens (again useless). In despiration, I decided to try to unplug the projector and did so for 30 seconds to allow the charge to drain from the circuits powering the chips in the 8700+. Upon returning power and restarting, the screen resolution appears/disappears properly once again. Give thjis a try.
Posted on Dec 04, 2007
SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
Posted on Mar 15, 2008
Kwitch
  • 33 Answers
SOURCE: touch pad quit working, fn-f7 doesn'make a difference
First, ensure that the button that enables/disables the touchpad is not deactivated if your unit has one.
If the keyboard still works, and you can navigate past your log-in password and enter your windows environment, here is a quick way to check and ensure your laptop still has the correct software driver for your touchpad mouse.
1: Press and hold your windows key, and press the R key.
2: This will open a run command prompt. Type "devmgmt.msc"
3: This will bring up your device manager. It contains all of the software drivers of your unit. If your mouse has a missing driver, it should boldly stand out from the list as an expended menu, within either your mouse drivers, or unknown drivers. You should see a yellow asterisk or exclamation mark next to the damaged or missing driver.
4: If the driver is missing, you can often re-download it from the manufacturers website and have the computer automatically re-install it once you have the driver saved onto your computer.
This solution is only for a single scenario though. Why your driver would have gone missing should it in fact be missing or damaged would still be questionable. It is possible that another program, such as a malicious spyware or virus, could have modified or deleted it. If that were the case, simply re-installing it would not erase the software that is causing damage from your machine.
This is only a software related fix. If it is hardware related, such as the touchpad hardware itself is defective or damaged, then it would need to be replaced by a certified technician, most likely at a service center. I would recommend taking it to your nearest Best Buy and having a Geeksquad agent inspect it, test a usb or ps2 mouse with it, and give you a better idea of which of the two possibilities (hardware or software) the fault is really being caused by.
Hope that helps.
Posted on May 01, 2008
  • 3 Answers
SOURCE: I cannot ger the projector to project the image on the laptop. I have held down the Fn Key and F8 to no avail
possible bent pins on the cable.
possible video card death in the computer.
but, most likely one of two things can remedy your problem :
- 1 - try to reselect the source on your projector, so that it is detecting the port where your computer is plugged in. if that fails to solve the problem.........
- 2 - right-click on the desktop, and select "properties". then select "displays", then try the "advanced" tab, and mess around in there. can't tell for sure what options you will be facing at this point, since i don't know what graphics card is in your computer, nor do i know how that card is interfacing with your computer.
good luck, and i hope i was able to give you some help!!!!
(funny thing is, i was on here trying to solve a projector issue i am having, and saw your question pop up on the screen, and figured i might be able to help).
Posted on Jan 16, 2009
  • 38 Answers
SOURCE: sony vaio stuck in presentation mode
Right click on your desktop, go to display and change your resolution to one that is more pleasing.
Posted on Mar 25, 2009
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Unable to connect projector
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 20, 2012 | IBM Lenovo ThinkPad T510 Notebook
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
Transfer screen image to projector
Hi. Try pressing the Fn+F7 key to toggle the display option if you to use a projector or into your laptop itself or BOTH. Hope this Helps
May 04, 2010 | Lenovo ThinkPad T61 Notebook
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My 3000c100 not working with projecter
try to press Fn + F7 to work with the projector or try pressing Fn + Spacebar...
Jan 21, 2010 | Lenovo Computers & Internet
Lenovo 200x laptop won't display output from VGA.
Check iwth some other laptop too.
Make sure to connect the projector to the right port.
Check the Device manager if the Projector is detected.
Sep 09, 2009 | Computers & Internet
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
Jun 13, 2009 | Lenovo M500 DLP Projector
My lenovo laptop 15 pin vga port not working and i cant use projecter.
To divert the video to the external video port automatically, connect the data projector to the video port and power up the data projector first and then the laptop. If you had power up the laptop first then you can toggle the video between the LCD screen and the video port by pressing the Fn key and the press the F7 key. Repeat this and you can toggle between LCD only, Data projector only or both on together.
Jun 05, 2009 | IBM Computers & Internet
BenQ PB7220 XGA DLP Projector Multimedia Projector Logo
61 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
