Question about HP Compaq DC7900 PC Desktop
Computer fan not working - HP Compaq DC7900 PC Desktop
  • 57 Answers
Replace the fan immidiatly to avoid your pc from over heating
Posted on Sep 06, 2010
Fan is too loud
Every computer comes built with a processor cooling fan system.
The fan's main function is to keep the processor from overheating.
After long periods of use, processor fans can start to malfunction.
If your eMachines computer's fan is excessively noisy, it will need some maintenance.
If you don't deal with a noisy fan promptly, your computer's processor could overheat and cause significant damage to your motherboard as a result.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Power down the computer.
Disconnect all cables and peripheral devices from the computer's back panel.
Rotate the computer so the back panel is facing you. Lay the computer on its left side.
Remove the Phillips thumb screws that fasten the right side access panel to the computer's frame.
Remove the side access panel from the computer to reveal the motherboard and all internal components.
Locate the cooling fan assembly near the center of the motherboard.
Remove all Phillips screws fastening the fan to the motherboard.
Disconnect the fan's power cable from the motherboard.
Then lift the fan out of the computer.
This will reveal the processor chip.
Place the fan on a flat work surface with the label sticker facing upward.
Use a thin, flat-head screwdriver to peel away the label sticker from the fan.
This will reveal the access hole to the fan motor's bearings.
Apply one to two drops of lightweight mechanical oil into the fan motor's bearings.
Replace the fan's label sticker.
Use a can of compressed air to spray the dust and debris from inside the fan blades.
Place the fan back into the motherboard on top of the processor chip.
Replace the retention screws and reconnect the fan's power cable to the motherboard.
Replace the side access panel and its two retention thumb screws.
Place the computer tower vertically, and then reconnect all cables and devices to the computer.
Nov 18, 2013 | eMachines EL Computers & Internet
My acer all in one desktop computer's fan isn't working. So my comp heats up. How can I fix the fan?
You need to replace the fan as soon as possible. Your computer might be in trouble running without fan. Just a clarification, what fan are you talking about? Is it the fan from the heatsink? rear or the front fan? But anyway, you can buy cheaper fan from any computer store.
Sep 06, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
The fan on my computer has stoped working what should i do to get it working
some times buy a normal house fan and put it close to the computer fan it should move it, if your computer overheats buy a laptop cooldown mat of amazon
May 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
HEAT SINK FAN NOT WORKING
1.Replace the new fan.
(or)
you can cut the processor fan ,then put any small size 12V exahsting fan in that place.and stick it with the help of glue.you can put the power supplies as mentioned below:
Yellow color wire = 12V
Black color wire = Ground.
Thank u sir.... All the Best...
Apr 22, 2010 | AMD OPTERON 240 (SERVER) 1.4GHz CPU RETAIL...
My fan does not work on my HP Pavilion Notebook
This sounds like an issue with the fan itself but may also be a motor driver or temperature feedback control / power management problem. Try replacing the fan with a known working fan. You can buy them at most computer repair shops and even Radio Shack I would not use the computer without the cooling fan working as the CPU may be damaged.
Aug 16, 2009 | HP Computers & Internet
Fan error
fan error means that one of the fans inside the computer has failed and is no longer working causing the system to overheat. to solve this you must replace the fan that isn't working. you should try going to your local computer hardware store and ask them to fix the problem.
Feb 26, 2009 | IBM (04P3161) Cooling Fan
Starting proplem
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Jan 19, 2009 | Compaq Presario SR1000T (568657) PC...
Asus Laptop freeze after starting
if the fan does not work... don't use the computer till you replace the fan with one that is working.... a good chance you will burn out the cpu. usually thermal shutdown occurs when the cpu gets too hot... you may also want to consider purchasing a notebook cooler....
Robert
Dec 17, 2008 | ASUS m6n Notebook
HP Compaq DC7900  PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
