Question about Goodman Heating & Cooling
Air is not coming on, can hear the motor but fan is not moving
  • Goodman Master
  • 43,501 Answers
Fan set screw is loose or the hub came out of the blower wheel...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 07, 2010
No heat coming through vent
Is there air moving out of the vent? Can you hear the fan motor running? Does air come out of other locations, such as the defroster or floor? What kind of car is it? These are the kinds of things you need to mention if you by an actual answer.
Nov 11, 2014 | Cars & Trucks
Mercury mountaineer heat
Yes, or the resistor.
Feb 03, 2018 | Cars & Trucks
Maytag air conditioner turns on but fan does not blow. When I put the unit to fan only, I hear the hum of the fan, but no air coming out.
Either the capcitor has gone bad for the fan motor or the motor has siezed up or gone bad... you cold try to replace the cap. first and move on from there....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Maytag M7D24E7A Air Conditioner
Air not coming out full force
Check the circuit breaker for the indoor unit. Also make sure the fan rotates freely by hand, then check the capacitor for the fan motor and replace it if bad. If the capacitor is good then check the fan motor windings to see if the fan is bad.
Jul 20, 2010 | Goodman Heating & Cooling
2003 trailblazer I have no heat or air coming out of my dash vents
Is it no heat/air when sitting still, or no heat air period? If the heat and air blow slightly when driving you have a bad blower mower/resisitor and its not allowing the air to blow into the cab. If not blowing period when moving probably bad heater controls or fuse... Worst case scanario is you have an electrical problem that needs to be diagnosed
Jul 15, 2010 | 2003 Chevrolet TrailBlazer
Hi, We have this system and when we on the unit...all we get is the sound of the system with no air coming out the vent...what should we do??
you should hear 2 seperate sounds; one of the water movement and/or water control, and the other of the fan and fan motor. If no air is moving and you hear a moderately loud hum sound, then the fan motor is stuck ( bearings probably worn or seized) and it will do more harm to allow it to be on without the motor running. Some motors can have their bearings repaired, other motors must be replaced. There are some units that use a fanbelt from the motor to the fan blade and it is possible that the belt broke. ou need to remove the access cover (with the power off) to see for sure whether it is a motor or a belt. goodluck, Macgivor
Jan 27, 2010 | Mastercool 67471 Evaporative Cooler Air...
The motor was making a humming sound, we stuck a screw driver in the unit to get the blades moving again it worked for a minute and now the blades aren't moving and we don't hear the hummming sound, there...
YOUR OUT SIDE CONDENSOR FAN MOTOR HAS WENT BAD ,REMOVE THE OUTSIDE FAN AND MOTOR TAKE WITH YOU FOR A REPLACEMENT MOTOR MAKE SURE THEY MATCHDON'T KNOW WHERE YOU LIVE BUT R.E.MICHAEL CO. IS A GOOD COMPANY
Aug 10, 2009 | Heating & Cooling
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
