Question about Kenmore Dishwashers
Top water sprayer not getting water. does not clean dishes on top shelf.
  • Kenmore Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 07, 2010
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
My dishwasher does not clean my dishes good
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Usually in the center of the spray arm is a wing nut. Simply unscrew this to remove the arm(s). Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 05, 2010 | Kenmore Dishwashers
Spray arms blocked how do I detach clear/clean them?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. In the center of the sprayer arm there is usually a wing nut that unscrews easily and releases the sprayer arm. Once you have removed the arms, rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | Bosch Dishwashers
The top section wont wash clean
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
The top spinner/cleaner dish sprayer thing isn't spinning or spraying water on to the dishes on the top shelf. The rest of the dishwasher works. Any suggestions on how to fix?
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishwashers Logo
114 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
