Question about Kenmore 24032\24036 Top Load Washer
Our kenmore 600 just started wobbling real bad on spin cycle. I am not sure what is wrong with it and why it is doing this.
Will not spin or agitate water works ok
Posted on Oct 05, 2010
Kenmore Series 80 washer. When the spin cycle starts, the interior basket wobbles and seems off kilter. I emptied the load and it still does it, so it is not an unbalanced load
sounds like you have a bad spin bearing. If the unit is over 4 years old, might not be worth fixing. I recommend not using that unit till you have it fixed or get a new one.
Mar 05, 2015 | Kenmore Washing Machines
What is wrong and how do I fix my kenmore 600 series washer?
If this is a top load washer; then the "LID Switch" is broken. Go to www.sears.com/parts, enter your model number and you'll see the switch listed.
Aug 26, 2014 | Kenmore Washing Machines
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
I have had my Kenmore 600 dryer serviced twice. Today, a thermostat was replaced. The timer doesn't advance, the clothes won't dry and water is leaking from the duct. Is there a problem with this model?
I don't see a lot of complaints from this model. There can be some moister
from the dryer, but not water coming out of the duct, clean the rear duct of the dryer to the outside vent to make sure you have full air flow and so you don't cause a fire if it is full of lint. Then check your washer, are the clothes real wet after the cycle is done, they should not be that wet after they spin,
if it was me I would spin them twice or see if there is a option to spin longer if they seem wet.
Feb 04, 2010 | Kenmore 62602 Electric Dryer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Kenmore 24032\24036 Top Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
