Question about Garden
Can't find model number on old sears wood chipper. with 5 hp B&S motor trying to remove impeller or flywheel plate Need model number to look for the owner manual
  • 2,926 Answers
The chipper wheel, with is heavy, is secured with a bolt or bolts to the crankshaft. Once the bolts are removed, you can hit the sides of the chipper/impeller with a mallet @ 12,3,6,9 o'clock positions to get it to break loose or use a puller to break it loose. The shaft is tapered, and this taper locks the impeller to the shaft as well as the bolt(s).
Posted on Sep 06, 2010
I'm looking for a replacement impeller for a 1 1/2 hp centrifugal pump (for irrigation) and the only info I have for the pump a partial plate on the electric motor. This pump probably is about twenty years...
Hi, If you have removed the old impeller, the part number will be in the center. If wear has obliterated the part number, then the replacement impeller will be either spx1610-c for medium head or spx1611-c for a high head. Later models of super pumps will have a 2600 series of numbers for the upgraded drive train. However, the 1600 series drive train parts are still available.
Nov 22, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I need a gas tank for a Craftsman 242-27006 shredder-chipper
go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears type in your model look through the pictures and you should be able to find the part number and sears can order it for you.
Feb 22, 2010 | PDP Systems 1.5 Horsepower Electric Wood...
Removing flywheel from chipper-shredder model number 247-775870
REMOVE THE FLYWHEEL NUT, CHECK FOR BURRS ON THE CRANKSHAFT, REINSTALL NUT LEAVING 1 OR 2 THREADS EXPOSED, APPLY UPWARD PRESSURE ON FLYWHEEL WITH SMALL PRYBAR BEIGN CAREFULL NOT TO DAMAGE ENGINE, GENTLY TAP THE END OF THE CRANK WITH A SOFT BRASS MALLET OR BLOCK OF WOOD
Nov 18, 2009 | Craftsman Gas Mini - Tiller/Edger
The pull cord is stuck, can't be pulled to start
This solution applies to the Sears model 358.797200, which also appears to the FL1500LE marketed under the Craftsman name, and may apply to other, similar, blowers. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment. (The binding may easily be misdiagnosed as a seized up engine.) The binding can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Oct 25, 2009 | Garden
Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
Oct 12, 2009 | Craftsman Gas Mini - Tiller/Edger
How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Aug 16, 2009 | Heavy Machinery
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Jun 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Apr 29, 2009 | Garden
Can't start Chipper
Unplug the spark plug wire FIRST.  DO NOT SKIP THAT.  Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse.  I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards.  You have to disconnect the spark plug because the engine could fire when you turn it.  Even if it doesn't start, one good kick could hurt you pretty seriously.  So, go unplug the spark plug and do your thing.
Apr 18, 2009 | Heavy Machinery
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
