Question about Toshiba Satellite p105-S6114 Notebook
I have a Toshiba Satelliet P105-S6114 my dvd rom does not work is it very hard to replace
  • 393 Answers
Open cd rom door just clean lense with soft cloth ...if same
remove cd rom romove top cover then romove buttom u can see on back of lense two veriable for lense adjustment try one by one one adjustment is for normal cd and one is for dvd cd dont try together.. move little bit...and clsoe and then check... Thanks
Posted on Sep 14, 2010
Need audeo driver
Vista and XP drivers are available here - http://support.toshiba.com/support/modelHome?freeText=1484717. I am unable to find Windows 7 or later.
Jul 06, 2014 | Toshiba Satellite P105-S6114 Laptop DC Car...
Download graphics card for Toshiba Satellite P105-S6114
You can download thevideo and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Aug 30, 2011 | Toshiba Satellite p105-S6114 Notebook
How do i resart my Toshiba Satellite P105-S6114 to factory settings without the recovery discs?
Quite simply, you cant. You would normally do this by inserting the original recovery disc in the cd drive and press F12 as you turn it on.
The only options available are asking Toshiba for the discs (for which they might charge) or see if you can find someone with the same machine and borrow theirs.
Dec 22, 2010 | Toshiba Satellite p105-S6114 Notebook
HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
I have a Toshiba satelite P105-s6114 and it is asking for a default password when I turn on... do you know what that password is or how I bypass???
Passwords are designed to keep people out!
default meants the password that was set by the owner. Initially there is no password. So someone has set one up.
The person who put the password in is the one who can open it. Sorry
Sep 05, 2009 | Toshiba Satellite p105-S6114 Notebook
I AM TRYING TO BURN A DVD USING TOSHIBA DISC CREATOR, BUT THE COMPUTER KEEP SAYING THAT THERE IS AN ERROR CODE : 0600277-26-28031100. HOW CAN I FIXED THAT?
try to re-install the toshiba disc creator driver and try to burn the cd again. if it doesn't work i suspected your dvd rom drive is faulty. you need to replace it. call toshiba and request to replace the drive.
if machine is under warranty no need to pay for replacement.
Jun 30, 2009 | Toshiba Satellite P105-S9722 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Audio level: satellite p105 s6114, conexant high definition audio
perhaps you need to adjust the master settings through control panel, sounds?
May 25, 2008 | Toshiba Satellite A135 Notebook
Toshiba satellite P105-S6104 DVD Rom wont open
If brand new return for replacement! It is fubar - supposed to be recognized by CMOS and your OS.
Sep 09, 2017 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite p105-S6114 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
