Question about Haier ESA3125 Wall/Window Air Conditioner
Outer unit produce ice after tempreture 21 - Haier ESA3125 Wall/Window Air Conditioner
    President:
  • 1,515 Answers
Hi, what you have is called a Heat-Pump, and it also has a reversing valve that reverses the flow of freon through the unit. In the winter time, the outdoor unit becomes the evaporator coil and the indoor becomes the condenser coil. You have what is called a defrost board and also defrost thermostats on the outdoor unit. When the unit starts to build up ice on it, it has a defrost timer and along with the stats will terminate a defrost and melt the ice away. You should see the fan shut down and the unit will start to throw off steam, almost looks like smoke. Ice is a normal thing to happen on heat-pumps as long as it goes through a defrost cycle every so many hours to keep the ice from getting real thick and the unit stops heating your home. So, if your not having heating problems, and the ice does not keep building and getting thicker and thicker, this is normal, and there is nothing for you to worry about. If you have any more questions, feel free to contact me and I will help you out. Please don't forget to rate this post for me, as I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 24, 2010
  • Virginia Bone
    Virginia Bone Nov 23, 2013
    My outdoor unit has ice build up but the fan is still running. I have been out to check it when the fan turns off but the compressor is still running (which I assume is the defrost cycle), however, the outter casing still has ice build up and I don't see steam coming from the unit. Is it possible to warm up the coil and not melt the ice from the outter case? There is only a 3 inch section of the combs that do not have ice on them...do I have an issue with my defrost board? I have used water to melt a large portion of the ice off the combs and then the frost/ice comes back (which I know is supposed to be normal...but it never melts off during the defrost cycle). It is an older unit (probably at least 10 yrs old)
The Ice machine wont produce ice.
here are some things to try first before calling repair person.
unplug the unit, if you can remove the unit , do it., IF NOT, JUST REMOVE THE ICE TRAY UNIT, leave unplugged for 30 minutes.
make sure the water is following, see if you get cold glass of water, this means the system has water, and IF NOT, check the line frozen or damaged,
after 30 minutes plug the unit back in, install the ice tray properly secured in place, make sure the leaver flush against the ice maker
it may take 1 hour or more and go look see if it producing ice
if it is not producing ice than call a repair person.
Oct 02, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
Freezer side is fine but fridge side wont get below 39 degrees
Nominal tempreture for your refrigerator is 36-38. on the Freezer the tmpreture should be between 0-2. One of the first things to check is on the freezer side is there any frost or snow build up on the rear wall of the freezer. If there were this is termed as a defrost issue. If you do have this issue with frost build up message me back and I will instruct you how to repair this issue. Another thing to check is if the evaporator fan inside the freezer is blowing the cold air into the refrigerator. The Freezer section is the only area that produces the cold tempreture a fan blows the cold air off the evaporator coils through a damper door that opens and closes depending on the tempreture the refrigerator side is set to. Also check the damper door for any ice build up as well this would cause the door not to open and close and remain in a stuck postion. This would cause inadequate tempreture in the refrigerator side as well. If you have any questions or need any schematics or step by step instructions message me back the model number of your unit and I will provide these and answer any further questions you may have. I await your reply
Thank you
Rick
Jul 12, 2012 | Frigidaire Refrigerators
CANNOT SET TEMPERATURE
Nominal tempretures for the refrigerator side are 36-38 degrees. Nominalk tempreture for the freezer section is 0-4 degrees. Your main board that controls your entire refrigeration can be found on this diagram as 1-5 http://c.searspartsdirect.com/lis_png/PLDM/50039314-00004.png
What tempreture are you trying to achieve? By setting the unit colder you also cause the unit to work harder as well shortening the lifespan of your refrigeration compressor as well as other key parts that perform to make your unit produce cold. Some key things to look for are any type of freeze up on the rear wall of the freezer which is termed as a defrost issue and if you do have this issue message me back and I can instruct you to solve this situation. I await your reply
Thank you,
Rick
Jul 01, 2012 | Samsung RB215LASH
Refrigerator turns off
Is the freezer still staying cold yet the refrigerator is getting warmer? The freezer in all refrigerators is the only side that produces the cold. open the door to your freezer and assure that the evaporator fan motor which is located behind the rear panel on the back wall on the inside of the freezer is running. This fan is what pushes the air through a small door located on the rear inside of the refrigerator that makes the refrigerator side become colder. If the fan is working yet you can not feel air coming through the small door you would then look at replaceing the door which is termed in some units as a damper door and others as a diffuser door or the tempreture control thermostat that is connected to the knob that you turn to make the refrigerator get colder. If you find any ice build up blocking the diffuser door it is best to just replace the door rather then trying to pick the ice out of the door part itself. If you have any further questions message me back.
I await your reply
Thank you,
Rick
Jan 02, 2012 | Refrigerators
My ge tfx30pp is not staying cold after running it on a generator for a week
Is the compressor kicking on and off? Is the freezer working OK?
Nov 14, 2011 | Refrigerators
Whirlpool fridge quit cooling
when you adjust the tempreture dial for the refrigerator this would turn on the evaporator fan motor located behind the rear wall of the freezer click this link http://c.searspartsdirect.com/lis_png/PLDM/00052094-00007.png part number 17 on the schematic would be the panel that you would remove when you remove this panel this would give you access to the evaporator coil as well as the evaporator fan motor if the fan is not spinning then you would replace the evaporator fan motor. If you see any ice build up on the evaporator coil or the fan motor or blocking the drain located under the evaporator coil this is termed as a defrost issue. If you find this then message me back and I will give further instruction on how to diagnose why your unit is haveing a defrost issue. The freezer is the only area that produces cold in a refrigerator. The evaporator fan motor blows the cold air through a small damper door that opens and closes depending on the tempreture inside the refrigerator. The first thing to check is the fan motor that is behind the panel that I mentioned. If you remove the panel and find that the fan is blowing and spinning message me back for further diagnosis. I await your reply Thank you
Rick
P.s what is the tempreture inside the freezer currently?
Oct 23, 2011 | Refrigerators
My fridge keep freezing every thing
If it were the freezer area and you had frost on the rear wall of the freezer I would say that your unit has a defrost issue. The freezer is the only area that produces cold there is an evaporator fan that blows the cold air through a diffuser or damper door located in the rear of your refrigerator. If the damper door is not closeing then your refrigerator side of the unit due to the door not being able to close would start to freeze items inside of it. Remove the diffuser door and assure that there is no frost blocking the fins or the door (some have fins that open and close others have a door ) do not have any frost build up or ice build up as well. Also assure that the door is able to open and close. If the door has ice, frost, or you are not able to open and close the door you would replace the diffuser door in the unit. If the door has no ice and opens and closes properly then you would look at the thermostat for the refrigerator which is located usually in the ceiling and is attached to the knob that you would use to make the tempreture on the refrigerator side colder. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. If you need a schematic of your unit message me back the make and the model number. Thanks again
Rick
Sep 17, 2011 | Liebherr Refrigerators
Thermostat dial broke and huge ice pushed out cover. Fan still works ok.
dear sir
i think in your air conditioner,s thermostat is not working because there huge of ice on unit. thermostat control to compressor for desire temperature, when temreture reach till desire tempreture it,s cut supply for compressor . and make balance on cool air.
please replace thermostat for solve this problem.
hope answer the question
thank you
please vote!
Oct 02, 2010 | Sharp AF-R100DX Air Conditioner
GE ice maker is getting hot
You need to remove the ice maker the function that heats the lower element should last only a few seconds so I believe the ice maker will need to be rebuilt or replaced. Sea Breeze
Jul 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Haier ESA3125 Wall/Window Air Conditioner Logo
169 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
howard thompson
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
