Question about Toshiba 50HDX82 50" Rear Projection Television
Toshiba Cinema Series MODEL 50HDX82
TV turns on but get scrambling lines can't view picture I'm not sure whether it's the same problem, but I do get those vertical squiggly lines when I turn on the 50HDX82 (4 years old) - it takes about 10 min for the image to stabilize, and that time increases by about 1min every week.
  • 1,512 Answers
Hi
Replace the capacitors(about 10 of them) on the Hyperboard 23148024. This should solve the problem. You can confirm this by heating this PCB when cold to prove that it is causing the problem. The fault will dissappear if you heat the parts that are causing your symptom.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 15, 2008
    Guru:
  • 1,894 Answers
Did u replace the vertical ICs?
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
It sounds like the TV is quite old, i would first try degaussing the set before writing it off as needing repair or replaced.
Please see this link here to see about degaussing the set yourself, its possible the tv has a fault but you could try the steps mentioned to see if that helps first.
Hope this helps.
Posted on May 12, 2008
    President:
  • 2,712 Answers
Hello Renrew,
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
Thank you for using FIXYA!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 18, 2008
    Just checking to see if your issue is resolved. If it is, please assign
    a Fixya rating for the Expert whose advice guided you to a fix.
    Cheers!
I have a toshiba 39"
On the TV remote there will be a button labeled ASPET or PICTURE SIZE or RATIO or ZOOM. Press that button while pointing the remote at the TV. Press it repeatedly until the desired picture size is acheaved. Not the cable remote but the remote that came with the TV.
Dec 26, 2010 | Televison & Video
So the colours match up on the left hand side of the picture, and progressively fan out towards the right. The convergence had to be lined up manually for to come to this view. As well the picture has...
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Toshiba 50HDX82 50" Rear Projection...
I have no sound
go to menu settings and check audio on?
Jul 10, 2009 | Televison & Video
The projection lenses vertical and horizontal lines are off level
Your convergence ICs have failed. replace both STK392-110 ICs
May 23, 2009 | Toshiba 50HDX82 50" Rear Projection...
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
Mar 13, 2009 | Toshiba Televison & Video
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 50HDX82 50" Rear Projection Television Logo
239 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
