Question about Mitsubishi WS-65909 65" Rear Projection Television
Hi . My name is Paul. ws65 909 is about 12 yrs old. Have a yellow swoop front top right to top left, and there is double image on screen. Any ideas how to fix? Thx
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Go into customer menu and select convergence, then advanced--if as I suspect it is skewed and will not adjust it is the convergence IC this set uses.
This model is one that uses just one chip for this---STK-393-110 and part is under 15 dollars on EBAY.
Good news: I have start to finish, step by step instructions for the do it yourself person for this repair in this set.
If you want the instructions we can find a way to get them to you, they tell you everything you will need and exactly how to do the repair.
If this information helped, rate this solution as very helpful as I do this for free.
SD TECH
Hi . My name is Paul. ws65 909 is about 12 yrs - 258ae96.jpgIC Chip used in model you indicate you have.
Posted on Sep 06, 2010
WD My Book- Model: WD5000po32 I can't find the software. I was told to go into WWW.WDC.com I still can't find the backup software.
WD SES driver (32-bit) download, and WD SmartWare Disk Image for Windows,
http://wdc.custhelp.com/app/answers/detail/a_id/5419/
Western Digital My Book Essential WD5000po32 unplugged from computer, and power off.
1) Under the Download heading to the far right, left-click on the blue -
WD_SES_Driver_Setup_x86.zip
A small window will come up on the right -
Opening WD_SES_Driver_Setup_x86.zip
Make sure there is a green dot in the circle to the left of - Save File
If not, left-click in the circle.
Now go below in the small window, and left-click on OK.
Another small window will come up on the left.
In the heading of this window tells you where the file will download to.
{Note* You can change where the file will go to. I am not including this information at present, so as to not confuse }
In the wording of the heading may be Desktop, or My Documents, or Downloads.
{If your computer has Vista, or Win 7 on it, it will be Desktop, Documents, Downloads }
Desktop: The file will be on your desktop screen. (WD_SES_Driver_Setup_x86.zip )
My Documents: Left-click on Start > Then on My Documents.
(Vista and Win 7: Left-click on the Windows logo button, then on Documents )
Downloads: Left-click on Start > Then on My Documents. DOUBLE-click on Downloads.
{Windows logo button, Documents. DOUBLE-click on Downloads}
When you see the file name, DOUBLE-click right on it.
The file is a Zip file. A Zip file, for one, is used to send large amounts of information over the internet.
The file has to be 'unzipped'.
After you double-click on the file, you will be taken to the Unzip Wizard.
Click on Unzip on the right side.
In the next window, (Installation Wizard), go to the far left side, and click on Extract All Files.
Click on Next, Next, and Finish at the bottom.
Now go back to the folder the zip file was in. There will be the yellow folder icon with a zipper on it, and the name of the file, and a yellow folder with the name of the file.
DOUBLE-click on the yellow folder with just the name of the file next to it.
In the names listed DOUBLE-click on WD SES Driver Setup (x86)
The SES Driver Wizard will lead you through installing.
(Left-click on Next, Next, Install, and Finish)
Same procedure for the second file - WD SmartWare Disk Image
For additional questions please post in a Comment. (Believe upper right of your page. FixYa is undergoing improvement changes )
Regards,
joecoolvette
Sep 11, 2011 | Western Digital My Book Essential Edition...
On my Toshiba Tecra when in GoogleChrome the the image on the screen is 25mm too far to the right. This makes it impossible to use the up/down key at the top right of the screen and the enlarge and...
Have you tried double clicking on the bar right at the top of the screen next to the minimize, maximise, close buttons? By double clicking in this area it'll change the size/shape of the browser screen, you can then reposition the window to the top left of your screen and then click and drag the bottom right hand side of his window once the cursor turns into a double headed arrow.
Apr 18, 2011 | Computers & Internet
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
There is a yellow ''swoop'' in the upper left portion of the tv and shadowing. The ''magic focus'' does not resolve the problem. When I try to adjust manually, the grid shows arched lines (''swoops'' along...
Sounds like you have a bad convergence circuit, it's what lines up your picture so the colors are correct. Most brands (excluding RCA) use the same basic design. There are 2 big ICs called STKs that normally fail, some resistors or fuses may also go. Its about $300-$400 bucks to have someone repair it. If you want to try it yourself, this link TVrepair will take you to a site that sells kits with the parts and step by step instructions on how to fix it. Good luck
Mar 06, 2010 | Televison & Video
Near the top of the tv the objects are double exposed with in blue and yellow color.At the top of the tv in a light color you can see a faint color of yellow and blue that sort of swoops down like a...
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Hitachi or look for your light engine online.God bless you and your house!
Nov 25, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Mitsubishi WS-65909 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
