Question about Toshiba Satellite M205-S4806 Notebook
No lites no power will not boot up ac power supply test ok
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 20, 2010
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
I HAVE A DELL INSPIRON 6000 SERVICE TAG HN98T61. THE AC POWER SUPPLY WELL NOT CHARGE THE BATTERY NOR WILL IT POWER THE LAP TOP. THE CHARGE LITE DOES NOT COME ON. I AM SURE OF THE AC POWER SUPPLY IS OK. IF...
Take a multimeter, and measure the VOLTAGE and AMPERAGE being emitted by the AC power-supply. If "none", or much less than the ratings printed on the label, then it's time to replace the power-supply.
Otherwise, it most-likely is the connector where the AC adapter is plugged-in to the motherboard that is not transmitting, i.e., electrically-disconnected from the motherboard.
Maybe, resoldering the leads from the socket to the motherboard will fix the problem. Or, take the laptop to a qualified technician, for proper repair.
Oct 17, 2010 | Dell Inspiron 6000 Notebook
Sudden death Acer Laptop model 4702z when it was powered from AC
our laptop will always use the ac and charge the battery no need to remove this. If your laptop (boots up) displays the black screen with tex at the start you are able to save the laptop maby not the stored info boot up beeps let you no of any problems
May 26, 2010 | Computers & Internet
Will not boot... black screen?
Try removing the battery completely and powering it up on AC power. Sometimes a dead battery (even if you're plugged in to AC) will stall a boot-up in its tracks. If this doesn't help, please reply back and let me know if anything changed.
Jul 09, 2009 | IBM ThinkPad T40 2373 Notebook
FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
Oct 04, 2008 | Lite On (PA41519B1) 150-Watt Power Supply
Vmx
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Jul 02, 2008 | Nintendo DS Lite Console
Toshiba Satellite M205-S4806 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
