Question about KitchenAid Dishwashers
My kitchen aid dishwasher model number kudmo3ftss3 ran a cycle, now there is water at the bottom of the drum and the dishwasher will not turn on.
  • 7 Answers
SOURCE: Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Posted on Jan 21, 2009
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
SOURCE: My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Posted on Jun 24, 2009
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
Kitchen Aid KUDI02FRSS2 - I have the same problem and called Kitchen Aid (Whirlpool). They originally told me the control panel needed to self-program and that I needed to let it run through one complete cycle before it would lock in the program. When this didn't work they told me the unit has water temperature sensors in it that controls the length of wash depending on the incoming water temperature. When I told them the house water temperature was borderline scalding they said they could send a repair tech out for $75 just to come to the house. I told them to forget it and could buy the control panel for $80 bucks and install it myself for free. I had a previous K/A dishwasher that ran for 30 years without a problem. This one was a problem from day one. Never again - Whirlpool or K/A
Posted on Aug 27, 2009
Kitchen aid dishwasher
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Apr 24, 2013 | Dishwashers
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
The wash cycles go on for 2 - 4 hours.
I know is sounds strange, but on a typical Kitchen Aid dishwasher, cycles can go longer because the the dishwasher is waiting for the water be raised to the proper temperature, especially during a hot rinse cycle.
Checking that the heating element is working would be the first thing to check.
If the heating element is working, the probable cause is a failed console (which controls the logic/programming of the dishwasher.)
Good Luck!
Apr 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Jan 21, 2009 | Dishwashers
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Drying problem
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
Feb 23, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
