Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Toshiba 42hp83 dusting
This toshiba just clicked off and did the red light blinks twice (possible stand-by mode). All of my setting were checked between shutf offs. The tv will only stay on 20-30 seconds. I want to try the fan cleaning, but have a wall mounted unit. Are the fans easy to access or will I need to dismount and remove all the screws to get to the fans?
thanks,
peter in modesto
  • 3 more comments
  • Anonymous Aug 26, 2008
    i have the same problem. i need help also!
  • maconester Oct 14, 2008
    I had the same problem. I took off the back cover, and vacuumed dust off fans. The tv worked fine for 2 days, now it keeps powering off again. The right fan doesn't seem to be working correctly. Does this mean the fans are bad and need replacement, or should I check something else first before replacing these?
  • Anonymous Nov 10, 2008
    TV stay on 30 second then turn off it self, then light blink twice.
  • Anonymous Jan 16, 2009
    I have the same problem... thought it was sleep mode, but it just powers down no matter what. On for a few seconds. Then off. After it turns off, the red light "double-blinks" repeatedly. two flashes, then pause, then two flashes and so on...
  • jakujawa1 Feb 28, 2009
    I have the same problem. We had a pretty serve thunderstorm last night, and this morning when I turned the TV on it would only stay on for like 30 seconds (then shut down, and the red light would blink). I have a surge protector on the TV, but I'm wondering if it still experienced some sort of excessive jolt. Any ideas?
The fans are easy to get to, but you'll have to take it off the wall. It has two fans. Both located at the top.
Posted on Aug 20, 2008
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
I am looking for the remote code to pair my toshiba 40xf355d tv to my sky hd remote. Can you help?
0156 works for me 3/1/2015
Turn on your Toshiba TV.
Press the TV button on your Sky remote control.
Hold the Select and RED buttons for several seconds until the LED blinks twice then release.
Press the TV button again
Enter the 4 digit brand code: 0156 - the LED will blink twice
Point the remote at the TV and press the Stand by button.
If the television goes into Stand By press the SELECT button to store this code.
If the TV does not go in to Stand by mode, press the TV button and repeat from step 6
Dec 14, 2010 | Toshiba Televison & Video
I have a toshiba 42hp83 that is getting no power whatsoever not even a stand by light.
Check ur power source?Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Apr 18, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42hp93
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
Oct 26, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Television shuts off after being on for 30-60 seconds.
I just had the same problem with mine (Toshiba 42HP85) The TV was fine and shutoff red light blinked twice, and you can turn it on agin right away then it shuts off again. The problem was there are 2 cooling fans you can here at the top rear of the unit, when they get dusty the bearings wear out and shut off. See if you can here 1 or both fans working. If only one is on, you can get a replacement from coolguys.com for 7.95 ea. model # is on the back of the fan. Replace both while you have the cover off, if that's the problem. The unit shutting off is the computer sensing there is a problem the red light is an error warning. Good Luck!
Aug 12, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
TV goes off as soon as it is turned on
Hey did anyone help on this? I have the same problem.
Nov 22, 2006 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
275 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
