Question about Dishwashers
Gianni Dishwasher DW101S-GI is flicking circuit breaker when turned on, been working fine till now
5 Suggested Answers
  • 833 Answers
SOURCE: Bosch SHU3306UC dishwasher stopped
dave...why did the breakers pop? Sometimes, this is caused by a floating ground...the voltage from the other side of the line comes across and starts to fry things like circuit boards. What did the electrician do? Did he check the connection at the dishwasher itself?
Posted on Dec 09, 2007
  • 7 Answers
SOURCE: GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Posted on Oct 16, 2008
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dishwasher will not run. I have checked the
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Posted on Dec 26, 2009
My whirlpool dishwasher not working...no lights on any of the buttons...was working fine...is there a fuse or circuit that is off?
amc henry
Yes there is a fuse or circuit breaker at the fuse panel in your home.
if circuit breaker, the breaker will be half off.. to reset turn all the way off and the on again. If it trips again your dishwasher may have a short be it the element, or the motor
Jul 25, 2010 | Whirlpool Dishwashers
I need to flip my circuit breaker on my dishwasher to make it work
you may have to many large appliances on the same circuit. you might try to
see how many appliances are on that circuit. if it is so try turning off other appliances and just run the dishwasher to see how it runs. if this works you
may need to increase the amperage on the breaker or split the electrical
circuit. if its on its on breaker try increasing the breaker amperage. good luck!
Jul 23, 2010 | Frigidaire PLD4555RFC Dishwasher
Dishwasher won't start
check that there is a fuse in plug or that it is still active
check fuse board might have flicked breaker
silly I know but be sure scoket is active.
And I have seen some dishwashers have a safty switch that it will not turn on till there is water going to it.
if new remove safty tape from door lock - will never turn on with this attached - clear tape - easy miss.best of luck.P
Aug 06, 2009 | Dishwashers
Lock light stuck on, dishwasher will not work
We had turned the power off at the breaker but only flicked it on and off, a friend recommended we turn off the power and leave it off for 5 minutes then turn it back on. This solved the entire problem!
Jul 10, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
