Question about Cameras
Rating your Solution
Hi, thank you for all your help. I tried all you suggested. In the end I had to right click on Start and select Explore. Now how do I rate your solution?
Cheers
    President:
  • 2,712 Answers
Well, if you get back to the original post, you should find four rating options at the bottom of my post. Simply select "Fixya". (I am not sure if this is the same with premium problems, as I cannot see the customers view on their monitor) If you do not see a fixya button, then there should be something else similar, like solved or fixed or something.
Here is a link to the post:
http://www.fixya.com/support/t555981-connect_fujifilm_s3500
If you can post a screen shot I could probably help.
Alternatively, you can try to send an email to the Fixya admin at experts@fiya.com, and they should be able to help :)
Just posted a comment on that post, maybe you will be able to see a rating button now..
Posted on May 12, 2008
  • Swilin Sampson
    Swilin Sampson May 13, 2008
    I believe you should see an "Accept" button. Please click on that to rate the solution..
    Thanks in advance.
Cannot find map data files
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 06, 2010 | Computers & Internet
My 200GB Maxtor has somehow changed from the storage drive to a local drive. Now Windows can't open this drive for viewing and keeps asking me to format the drive. It was working fine till last weekend as...
Suggestion 1:
Try exploring the drive from Disk Management:
1. Click Start
2. Right-click My Computer
3. Select Manage
4. Select Disk Management
5. Right-click the inaccessible drive and select Explore
Suggestion 2:
If that doesn't work, try changing the drive letter:
1. Click Start
3. Select Manage
5. Right-click on the inaccessible drive and select Change Drive Letter and Paths
6. Click the Change button
7. Select a different letter from the available drop down menu
8. Click OK>OK
Perform the same steps from suggestion 1.
If the drive is still inaccessible, it's likely that somehow the NTFS master file table (MFT) has become corrupt which is causing Windows to believe it needs to be formatted. Unfortunately, it's not an easy to task to return the file system back to its correct state.
It may be possible to use a file recovery application such as Stellar Phoenix Photo Recovery to recover the lost data. It's relatively cheap for one of those programs and may help you save a good chunk of your data. Here is the link to Stellar Phoenix Photo Recovery:
http://www.stellarinfo.com/
I used it once when I forgot to format my memory card in my camera. I was able to save 230/250 photos.
Hope this helps. Good luck!
Aug 09, 2009 | Maxtor (6Y200L0) 200 GB Hard Drive
Windows live messenger login but contacts cannot list
First i should say, this had to be a paid solution lol
  1. On the taskbar, right-click Start, and then click Explore.
  2. Click Tools, and then select Folder Options.
  3. Click the View tab.
  4. In the Advanced Settings list, select Show hidden files and folders, make sure Hide extensions for known file types is not selected, and then click OK.
  5. In the Windows Explorer window, click View, select Explorer Bar, and then verify that Folders is checked.
then
  2. Navigate to the folder C:\Documents and Settings\Your Windows logon name\Contacts\Your Messenger e-mail address.
  3. Delete all of the files in the folder.
  4. Navigate to the folder C:\Documents and Settings\Your Windows logon name\Local Settings\Application Data\Microsoft\Windows Live Contacts\Your Messenger e-mail address.
  5. Delete all of the folders and hidden folders in the Your Messenger e-mail address folder.
  6. Close Windows Explorer, and then try to sign in to Messenger again.
Try this for windows xp.
for vista
  2. Click Organize, and then click Folder and Search Options.
  5. Click Organize.
  6. Under the Layout menu, verify that Navigation Pane is selected.
then
  2. Navigate to the folder C:\Users\Your Windows logon name\Contacts\Your Messenger e-mail address.
  4. Navigate to the folder C:\Users\Your Windows logon name\AppData\Local\Microsoft\Windows Live Contacts\Your Messenger e-mail address.
A bit big, ryt?
Apr 01, 2009 | Microsoft Windows Live Messanger
Contact List
then
for vista
  5. Click Organize.
then
A bit big, ryt?
Mar 30, 2009 | Microsoft Windows Live Messanger
Everything but the navigation (X4-T) on my GPS works...any suggestions?
You will probably need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  5. A menu pops up.
  12. Click "Start"
Good luck.
Mar 25, 2009 | Nextar X4-T Car GPS Receiver
Needprogramtodownloadpicturesforcamera
try the following workaround:
1. Plug in the camera to the PC and ensure it is detected by the PC.
2. Right click START button and select Explore.
3. From the left panel, scroll to the drive corresponding to your camera. (It will usually be located after the last DVD/CD ROM Drive letter.
4. Click on that drive to expand the folders in the right pane.
5. Search for the relevant pictures from a folder within that drive.
6. Copy the required pics (Hold CTRL and click on pics in case you want to select more than one pic). Then rt click and select "COPY"
7. Once you copied all the needed pics, select a folder on your computer (or create a new one) and paste the pics into this folder.
8. You're done :)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 26, 2008 | Cameras
Usb
After plugging your USB to the PC, go to Windows Explorer (right click START and select Explore).
In the left panel, scroll down until you see your device listed there. It will usually be the drive after the DVD/CDROM drive.
Click on the (+) to expand the folders. Find the folder that holds the Mp3 songs. In the left pane, right click on this folder and select 'properties'. In the General tab, at the bottom, you should see Attributes. Make sure "Read Only" attribute is unchecked.
Try to copy paste Mp3's into this folder now. It should work.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
IrishDruid
May 28, 2008 | iLO (2 GB) MP3 Player
I AM TRYING TO TRANSFER FILES FROM XP TO NEW VISTA COMPUTER BUT AM HAVING TROUBLE. i GO TO EASY TRANFER, FOLLOW INSTRUCTIONS BUT WHEN I GET TO PLUG IN MEMORY STICK ITS THEN TELLING ME TO INSERT MEDIA....
1. Have you tried inserting the memory stick after it asks you to insert media? Try it...
2. If that doesn't work, don't use the Easy Transfer option. Simply plug in your memory stick, wait for it to get recognized and initiated, and simply drag and drop using Windows Explorer (Right click START button and select 'Explore').
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Cheers!
IrishDruid
Apr 29, 2008 | Computers & Internet
Cannot find "c:\Acer\eManager\eManager.exe
1. First make sure that you or anyone with access to your computer has not deleted the software.
2. Try the SEARCH feature: START > SEARCH > (from left panel, select "All files and folders").
Under "All or part of file name", type eManager.exe.
Make sure you select the C: drive under "Look in". You should see the results in the right pane.
3. If you cannot see that listed when you actually get there in Windows Explorer (START,right click and select 'Explore' to bring up Windows Explorer), click on TOOLS (at the top of the window) > Folder Options > View Tab > Hidden Files And Folders. Here click on "Show hidden files and folders". Now you should be able to see all hidden files.
Cheers!
IrishDruid
Adding a sound for alarm use
Copy the sound you want into the windows folder.
Aug 31, 2007 | Orange SPV M2000 Pocket PC
Cameras Logo
43 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
