Question about Sagem my100X Cellular Phone
Code phone - Sagem my100X Cellular Phone
  • 527 Answers
Posted on Nov 24, 2010
Is the unblocking code same as the puk code
Thanks for visiting FixYa!
There are several security codes used on cell phones. I'll try to define each:
1) Limited access code: This is a pre-set code that limits the phone's use to dialing or receiving only pre-programmed numbers. For example, an employer gives a company phone to a delivery guy which will only make calls to -and receive calls from - the office.
2) Security codes:
a) Software security unlock code: Most phones are locked to accept only apps (software) from approved venders. This code is used to unlock the phone so it will download and install third-party applications.
b) User Security Codes (or Blocking codes) : This code unlocks the phone so it can be used to make and receive calls. Without this code the phone is 'blocked' from making or receiving calls.
PUC Code: This code is required when a security code (or block code) has been entered incorrectly too many times. (For example: Someone finds a lost phone which has requires a security code to use the phone, and attempts to guess the code several times.) Once this happens, the phone becomes locked to where the security code can no longer be guessed. A PUC code must now be entered. And, the only way to obtain the PUC Code is directly from the cell phone company that provides service to the phone. (A PUC Code is sometimes referred to as a Master Unlock Code.) Without it, the phone can never make calls again. Attempting to guess the PUC code 10 times can/will damage the phone and the SIM card if the phone has one.
SIM Unlock: Sim Unlock, or Network Unlock is a code which when entered on the phone allows the phone to be used with different cell phone companies.
Jun 27, 2011 | Nokia 6600 slide Cellular Phone
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
Mar 12, 2011 | Sony Ericsson Cell Phones
I forgeted security code of my nokia 6303 classic phone
Hi welcome to fixya.com.If you did not set the security code, it should be 12345.
When you enter 3 incorrect code, any codes correct or incorrect after that will be code error.
You need to turn your phone off then back on, wait at least 15 minutes , enter code.
You can only try 3 different codes at a time.
First Try it:
You may try default phone and security code to remove it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
if
OR:
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
please feel free to ask your questions on fixya. Have a nice day. Bye
Mar 11, 2011 | Nokia 6303 Cell Phone
Forgot security code
First Try it:
if
OR:
Feb 11, 2011 | Nokia 2760 Cellular Phone
HOW I CAN REMOVE MY PATTERN CODE LG GT540
First Try it:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
OR:
Jan 24, 2011 | LG GT540 Cell Phone
My n73 displays message"memory full,please delete some data" but my phone memory is completely empty
USED THIS CODE TO REFORMAT YOUR PHONE *#7370# AFTER YOU ENTER THIS"RESTORE ALL ORIGINAL PHONE SETTINGS?PHONE WILL START"WILL APPEAR ON YOUR SREEN,PRESS YES, & THEN LOCK CODE.IF YOU CHANGE THE DEFAULT SECURITY CODE OF YOUR PHONE,PUT THAT CODE,IF NOT PUT 12345 AS THE DEFAULT CODE.WAIT UNTIL YOUR RESTART.DONE....GUDLOCK
Mar 03, 2010 | Nokia N73 Cellular Phone
I have an N70, Do you happen to know the Master Reset Code
The default security code for Nokia is 12345
IMEI: 357968007960658
Master code: 7176552371
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Jul 15, 2008 | Nokia N70 Cellular Phone
W850i
you would need to take the phone to a mobile center to have them master reset the phone p/w.
May 29, 2008 | Sony Ericsson W200i Cellular Phone
Can't remember my phone lock code
If you have the USB cable for the phone you can read you phone code with setool2lite. Setool2lite is a free soft for customizing SE phones.
May 21, 2008 | Sony Ericsson W700i Cellular Phone
Sagem my100X Cellular Phone Logo
48 people viewed this question
Top Sagem Cell Phones Experts
Pavel Pranovich
Pavel Pranovich
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sagem Cell Phone Expert? Answer questions, earn points and help others
