Question about Dopod 828 Smartphone
Hi! Hope you can help me - everytime I use my stylus on the screen, it just doesn't work.It's like the whole screen has entirely frozen and is impenetrable.However, when I use the keyboard, my phone works.I have never accidentally dropped my phone or gotten it wet.Sadly, I'm really used to using my stylus instead of the keyboard. What causes this problem , that the whole screen does not respond to my touching icons with the stylus? I've tried to turn it off completely then turned it on again but this did not work.I'm not a techie so don't know if there is any other way I could try to fix it.Hope somehow you can fix my problem.THANKS HEAPS!
3 Suggested Answers
SOURCE: my dopod turns blank
Display driver issue. Send back for warranty.
Posted on Sep 14, 2007
  • 5 Answers
SOURCE: d pad keys do not work
the dopod 838 is a real pain in that all the screws loosen themselves up. just tighten them up and they should start working again
Posted on Aug 01, 2008
I havew an Apple laptop 2004 computer and everytime I try to use Yahoo mail a colored circle appears and revolves around the whole screen.How do I solve this from happening?
Hi
hope you have fixed the problem by now.
Try clearing your browser history and also all cookies. Since I do not know which browser you use you must find this at the developers homepage.
Hope this helps
Sep 20, 2013 | Apple MacBook Laptop Computer Mac...
Trio t2810c screen frozen
Look at the top of the unit. There is a small silver dot. This is the reset button.Push on it with a pin head or a stylus. It will return the screen to the main menu. Hope this helps.
Dec 25, 2011 | Mach Speed T2800 MP3 Player
Thanks for your help. as soon as i turn on the tv there are white lines across the screen that shouldnt be there. and the entire screen slowly fades to white at the same time as sections of the tv freeze...
Tv still have audio sound after it is turn itself all white on the tv LCD screen panel?Yes.Than this problems it is the tv main tv Tuner signal board it is dying and the causes.That the board,where the tv imcomming broadcasting signal cable wire plug into it.U have some skills,like can do some basic mechanicals works like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main tv Tuner signal board for the replacement.
Aug 15, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
Hi, i'm trying to change the cartridge on my epson stylus sx215 for the first time. The black ink cartrigde is completely out and the screen is saying the ink is expired. but everytime I try to press...
You should start the printer and open the lid When u see that cartridgeholder slide all the way to the left you pull the plug. After that you plug it in again n the cartridgeholder will slide back in place slowly. When you see the cartridgeholder in the area where you can open it you pull the plug again.
This is how i got it to work again..hope i helped..
Aug 01, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Power comes,but screen doesn't work. Repairer says no hope for repairing,replacing chipset will not work.
Try to reinsert the memory module/s if you have not tried it yet. If yes, you need to replace the whole motherboard and it should work again.
Hope this helps.
Jun 11, 2011 | Computers & Internet
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
Hi, I have a Casio Classpad 330 and I have problem with my touch screen. There is nothing happened when i tapping on the screen, but the keyboard is working properly. It seems it is damaged or corrupted....
I can give you the following suggestion.
The touchscreen will recognize your
stylus tapping if you simultaneously
have any of the keyboard buttons pressed (except 'Clear').
Once you see the whole menu (after screen
calibration and brightness settings) press
Clear than Exe than Clear and the screen
should be touch sensitive again.
Hope this helps.
Sep 08, 2010 | Casio ClassPad 300 Calculator
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
My Olympus Stylus 500, doesn't work the flash
hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Jan 28, 2008 | Olympus ? Stylus 500 Digital Camera
Main screen frozen
get a refund say it scewed on ya iv'e tried evry single thing i can do and every thing there is to do but nothing worked this is the option so do what i told ya get a refund you'll get your cash back or a new one or a new bettar model cause that one screwd on ya and it was their fault. hope this is helpfull. from helpfull anime
Aug 04, 2007 | SanDisk Sansa e260 MP3 Player
Dopod 828 Smartphone Logo
41 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
