Question about Archos AV700 TV Digital Media Player
I need a User guide & accessories for a ARCHOS AV 700 DVR device
  • 8,197 Answers
You can get the manual on the link below.
http://www.instructionsmanuals.com/u2/pdf/photoPC/Archos-AV700-en.pdf
You can get accessories on the links below.
http://www.boxwave.com/products/easyfinder/buy-best-archos-av700-accessories_2782.htm
http://www.pjbox.co.uk/Archosav700-accessories.htm
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 05, 2010
Dc power input for av700
This isn't really a good answer but there was an external charger available at one time that was fairly inexpensive. The one I got came from China. http://www.newmp3technology.com/multibox2-700.htm
Jan 01, 2013 | Archos AV 700 160-Hours Video Recorder
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
Aug 18, 2010 | Archos DVR Station MP3 Player
How do I transfer recorded programs from my 622 DVR to my home computer?
http://www.dishnetwork.com/downloads/user-guides/receivers/622_UserGuide.pdf
User guide. above.
You would have to connect up, using a PC & DVR software and some form of TV/Video recording Card, or USB device. Then connect up via AV, Composite, Yellow, Video. White & Red Audio. and "Capture" either live video & Audio, so basically whatever was viewed on the screen, would be "Recorded" on the PC, via the TV/Video interface device, if using a laptop, then a USB "Dongle" & software would be the best. In a Desktop, a PCI-I card would be Best, Then using the Software that comes with the devices, you "Record" with that and "Play" with the Dish DVR, and save, the Streamed Video & Audio to the PC. Now, If you have Component Out, on the Dish, then this is the one to use, If you choose this way, remember the Device you are going to use Must have a Component INPUT as well, as A Stereo Audio Input, so ensure the device you get has that feature.
Mar 30, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I do not know how to use the dvr station in order to transfer tv progams to my 504 i do not have the owners manual only the user guide
Here's the link for the Archos user manual: http://www.archos.com/support/download/manuals/english_-_user_manual_-_archos_504-604_-_v2.2.pdf
or just click here Archos.com
Mar 09, 2010 | Archos 504 500870 Digital Media Player
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
Sound problem
Make sure that the sound cables are connected,If you are using the RED BLUE GREEN cables,they do not carry sound.You have to run a set of sound cables RED AND WHITE to the Archos from the cable BOX or whichever component you are recording from.Good Luck.
Dec 29, 2007 | Archos AV 700 160-Hours Video Recorder
Archos AV700 TV Digital Media Player Logo
180 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
