Question about Singer 1507
Why is my bobbin thread binding up? - Singer 1507
    Genius:
  • 1,788 Answers
Maybe it is not threaded with the thread unwinding in the right direction. Try flipping your bobbin around and see if that answers your problem.
Posted on Sep 13, 2010
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
When sewing, mechanism sometimes binds. Bigger problem is when finished stitching, the hand wheel binds completely. Is there a mechanical problem or someplace to insert oil?
Hello Griff
Very likely the thread is kind of bound up in the bobbin area. Just turn the hand wheel a bit forward and backward several times -after you lift the foot. Apply a gentle pull on the fabric and it should "break" loose. Often teh thread is still stretched around teh bobbin and this releases it.
Feel free to reply to this post if this does not do it.
Moses
Dec 07, 2014 | Singer 7436 - INGENUITY
Mega quilter binds thread under fabric
If you have to manually set the tension on your bobbin, your tension may be too loose or too tight. When my bobbin is full of thread the tension has to be stronger than when it is almost empty. So tight when it's full and loose when it's nearly empty. I hope this helps. If this doesn't work try using a air can to blow out the dust in your bobbin casing and make sure the bobbin doesn't have any burs. It needs to be wound smoothly. Also check for thread hangups in the bobbin casing area. Also you may want to completely re-thread your machine.
Jan 02, 2014 | Sewing Machines
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem...
To:
By ladydiane56 on Jul 10, 2011
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem still there. Need some advise. Thanks
It sounds like the tension between the top and bottom threads isn't balanced. With the machine threaded, pull both threads towards you and feel if one is tighter than the other and if so, adjust the tension. Top thread adjusts with the tension knob on the front of the machine, bottom thread adjusts where you load the bobbin. Could also be that the bobbin is sitting in the shuttle the wrong way. Have it sitting in the shuttle so that as you look at the open shuttle and pull the thread, the bobbin turns clockwise. Hope this helps.
Jul 10, 2011 | Brother Sewing Machines
I have a kenmore model # 1581212180. My top thread is looping and when I change the tension then I get where the thread doesn't even stay in the material. I don't have a manual any longer.
Sounds to me like your bobbin tension is way too tight. Adjusting the top thread tension will not correct this. Either something is binding up the bobbin (thread or lint) do you wind your own bobbins? Perhaps you have a little too much thread on the bobbin and it acts like a break, stopping the bobbin from spinning freely. Check, clean and oil your bobbin shuttle (the thing that spins around the bobbin).
Hope this helps!
Chris
glfi.com
Jan 20, 2011 | Kenmore Sewing Machines
Machine is jammed and will not budge,,,hand wheel will not turn
Look into where the bobbin is. Did you break a needle and part of it is jammed in the bobbin shuttle? Did you have a thread binding problem and thread is now caught in the bobbin shuttle area. Clean the debris from the bobbin area and see if this is where the problem lies. 99% of the time it is. Remove the bobbin and look close for thread rapped around the bobbin shuttle.
Chris
glfi.com
Jan 20, 2011 | New Home HF-106
Why does the shuttle hook grab the spool thread instead of the bobbin thread? It wraps the thread around the bobbin and binds the machine up.
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
Nov 13, 2010 | Necchi Sewing Machines
My bobbin binds up quite frequently. I pull it out to find that thread has wound around the post under the actual bobbin in the bobbin case
Is the case in correctly, in the correct direction so that the thread is not unwinding?? Also make sure area is free of dust, threads & has been oiled recently.
Sep 26, 2010 | PfaFF Quilt & Craft Pro 7530
Bobbin thread pulls to the top with all but Brother brand
Your machine was designed to work with the Brother brand of bobbin thread. Any other thread will cause tension issues. If you want you machine to work with another brand of bobbin thread I suggest purchasing an additional bobbin case and have it calibrated for use with the other brand of thread.
Mar 17, 2009 | Brother SE-270D Computerized Sewing...
Singer 1507 Logo
76 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
