Question about Briggs & Stratton Lawn-Boy 10642 20-Inch 6.5 HP Gas Powered Variable Speed
My B&G Lawnmower Model#10642 is spitting out and leaking oil. What could the problem be?
  • 252 Answers
Sounds like you might have too much oil in the sump or a wet sumped ( had a engine flooding )
does the oil in sump smell like petrol and runs like water if you tip some out ? if carb is not shutting of fuel flow
if so drain and refill to correct level andgive tank and carb a thourgh clean out and check / replace needle and seat in carb, check float for fuel inside float ?
then check that breather is not stuck closed and is allowing pressure build up in crankcase and forcing oil past rings into the combustion chamber
is the oil comming out of muffler ?or from somewhere else ?
check for a tight inlet or exhaust valve
have look and let me know what you find
cheers pauly46
Posted on Sep 10, 2010
My craftsman lawnmower is leaking oil.
Check the drain plug, maybe it loose
Jun 19, 2014 | Craftsman Garden
My poulan lawn mower won't pull....
Check the oil level, sounds like you have overfilled the crankcase with oil.
May 28, 2014 | Poulan Garden
I need an engine diagram to help me put my lawnboy 10642 briggs and stratton eng ine back together
Go to partstree.com and search your model number and you will see an exploded view. Thank you for using fixya.
Aug 22, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
Brand new mower smoking on first start
tie a rope on the handle and allow it to run for 5-min with no load on it if it doesn't clear up then return it to the store you bought it at
Aug 04, 2012 | Garden
I pulled out the pug to recharge the starter for key start, and lost the outer plastic casing to plug it back in. Can I order the casing for the exposed prongs
The 10640 model does not have an electric start that I can see. Are you sure you have to model number correct? The 10642 and 10642C models are electric start. I will use the 10642 as a parts reference.
The electrical assembly is here:
http://www.partstree.com/parts/?lc=lawn_boy&mn=10642%2C+20in+Mulching%2FRear+Bagging+Lawn+Mower%2C+2009+%28SN+290000001-290999999%29&dn=3361337A-392215-0007
Where did you pull the wires out from? The battery box? The mower harness? The switch?
From looking at the parts available you should be able to figure out which part you need to replace.
Kelly
May 22, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Have a victa lawnmower 4 stroke engine when i started it recently it spits out oil and overheats pretty quickly its only 6 months old. checked oil it was full but i tried to turn it on again the same...
Check that the oil level is not too high, further than that do not do anything. As far as I can remember, Victas have a one year guarantee. Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Apr 07, 2011 | Garden
Large rattle in the engine, No oil leaks, belts re
Take the serpentine belt off the engine and and run it without it for a couple of minutes. Did the noise go away. If it did then it's accessory related if not it's engine related. Possibly a stuck lifter. Just spit balling here. Need more info.
Apr 08, 2010 | 1999 Ford Expedition
Briggs & Stratton Lawn-Boy 10642 20-Inch 6.5 HP  Gas Powered Variable Speed Logo
656 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
