Question about GE JES1290 Convection/Microwave Oven
Bright flash inside microwave
When making popcorn only, about half way done with popping a bag, that is the approved size, a big scary flame shoots from the small rectangular thing inside the microwave on the right side. So bad, we shut it down immediately. We have not successfully made one bag of popcorn since we got the machine.... other than that the microwave seems fine.
  • NobleGAs Jun 04, 2008
    We got the same flame and zapping sound with our oven so we returned it under warranty. Our new one does the same thing! My concern is a fire hazard because the cover over the microwave emitter is a coated paper and was scorched on the oven we returned.
    It seemed that fat deposited on the metal wall of the microwave seeps down behind the paper and ignites. This is what the evidence led me to believe when we examined the old oven.
    It seems the best solution is to cover any food when you put it in the oven.
  • Anonymous Jun 11, 2008
    I called GE on this problem, they sent a technician out to the house. The tech said the microwave would need to be replaced. He ordered a new one immediatly and it was delivered three days later. No cost to me! It makes popcorn!! yea
    Problem Solver:
  • 9 Answers
Try a different brand of popcorn & let me no what happens
Posted on May 12, 2008
Hey Guest let us know if you have anymore problems because our new oven still arced. It is fine if we cover the food to prevent spatter.
Posted on Jun 11, 2008
I called GE on this . They sent a technician to the house, he said that the microwave would need to be replaced. He immediatly ordrered a new one and it was delivered three days later. and it makes popcorn! yea!! Turns out the machine was still covered under warranty. no cost to me !!
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
Mar 18, 2012 | Hamilton Beach Microwave Ovens
Daughter put tin foil in microwave. Now it take 5 min to pop a half a bag of popcorn. And won't make a baked potato at all.?????
any exposed metal will burn up a microwave.Unless it is a very exspensive model,It will cost more for a repairman to fix than it would to replace
Oct 11, 2010 | Maytag Microwave Ovens
We can't get our microwave to fully pop the bag of popcorn. If we use the popcorn button it stops before the bag even starts popping. If we preset the time, the same occurs and if we run it until its...
Always place the bag of popcorn on an upside-down paper plate.
This allows more microwaves to penetrate the bag from the bottom.
Also always place food of any kind in the microwave off-center on the tray, NOT in the middle of the tray.
Not only does it cook more evenly (think of how you stir liquid) but it also prevent the same spot from being heated repeatedly on the glass turntable, which can lead to overheating and breakage.
Sep 06, 2010 | Dacor DMT2420SS Microwave Oven
What is the best microwave popcorn for my dacor microwave we just got it and i thought i would try some microwave popcorn it did not work very well the turntable just keep turning but the popcorn did not...
Put any microwave popcorn on a up side down dish so it is about in the middle of the oven. Make sure you follow the "this side up" instruction on the bag.
I am a microwave pop corn wizzard.
Jan 17, 2010 | Dacor DCM24 Convection/Microwave Oven
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
GE JES1290 Convection/Microwave Oven Logo
1,246 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
