Question about GE Dishwashers
Ge dishwaser will run but wont spray any water
  • GE Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 07, 2010
Frigidaire dishwasher model#fdb105ores2dishwashersime friendly format 80e
Hello friend, thank you for your post!
Your water valve or spray arm could be the reason no water is getting to the top of your dishwasher. Remove the spray arm and clean it out with warm water. Also check to make sure that nothing is obstructing the spray arm from releasing water onto the dishes. I hope this information is helpful. -Matt
Sep 02, 2014 | Frigidaire Dishwashers
Dishwaser will not empty the soap, does not matter if it is the cubes or crystals
Run it empy one time and see if it does the same thing. If it does then there is a water distribution issue. The spray bar is not getting enough water through it. If it does not work right when empty you should inspect the spray bars for plugged holes and then check the sump and pump area for debris. If the machine works when it is empty, check to see if you are loading it in a manner that obstructs the soap dispensor.
Jun 09, 2013 | Westinghouse WWBD2400HW 24 Inch Built-In...
WHERE CAN I FIND A GE TRITON DISHWASHER SCHEMATIC? thanks
On most dishwasers if you take off the bottom panel and look up inside by the water valve you will find a schematic.It's always folded up into a really small piece and tucked into a small black plastic bag.
Apr 07, 2011 | GE Dishwashers
Water not draining in the bottom of the dishwaser,no power at all
if you have a row of buttons on the left side for heat cycles check them a shorted switch will cause a loss of current situation so that the drain solnoid wont activate
Oct 12, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Water does not spray into dishwaser
the spray armes need to clean the small holls by asuitable stick
then if not solve the problem check the inlet pump underneath the m/c .
that will solve !
thanks
Jul 11, 2009 | Whirlpool Dishwashers
I have a GE PDW8060GSS dishwaser. The washer does not turn on. The "anti bacterail" swith keeps blinking. There is some water standing inside the washer. Tried draining, but water keeps coming back. Not...
If after draining water comes back then you need to check the waste water system for any cloughs. Problem might even be at the dwelling drainage system as any blockages would prevent water from going out from washer. Check the waste hose, filter and pump. clean them all if needed.
Best of luck
Jul 09, 2009 | GE Profile PDW8060GSS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwaser Fills But Does Not Run
You may have a problem with the spray arm being blocked or the water valve may not be letting a sufficient amount of water through to get the spray arms activated. If the dishwasher is still in warranty schedule service before it runs out. GE customer service number is 800-626-2000 model and serial numbers and purchase dates are helpful. Ask specifically if any kits are available to fix these problems and if GE is willing to make any concession toward this repair. Good Luck.
Dec 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
133 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
