Question about SanDisk Sansa m230 MP3 Player
Can't disconnect I can't seem to disconnect my device from Rhapsody or from just using the Safely Remove Hardware option. It says the device may not be disconnected now, try later. I'm afraid to just unplug it!
So why does it ask you? Is it ok to do even under vista?
Posted on Oct 25, 2008
  • SanDisk Master
  • 6,487 Answers
Try this Open Mycomputer>right click the device there and select Eject, if still the same problem you can really unplug it without the safely remove hardware.
Posted on May 12, 2008
I have a Transcend JF V30 -16 GB pen drive. I can add files to it once connected. However, if remove it and then reconnect it, files are not shown. The disc size is reduce as the data added previously. FAT...
Are you using the Safely Remove Hardware option? There should be a little icon in the tray that allows you to remove the drive safely. Alternatively, you can right click on the drive letter in My Computer and click Eject and/or Safely Remove to make sure Windows really does write your files to the disk. If that doesn't help, try reformatting the drive; if it still won't work, you probably have a defective drive, and you should try and return/replace your device.
Mar 01, 2011 | Electronics - Others
Tip
Unless you go into the device manager of your computer and change the settings to optimized for performance, you do not have to use the safely remove hardware option, you can just unplug it because it is set by default to optimized for quick removal.
on Jun 22, 2010 | Computers & Internet
The sandisk will not allow me to safely remove. when i click on u3 launcher
If you are using a version of windows, there is an icon in your system tray(bottom right hand corner of your monitor) which you should use to disconnect your device. If you let your mouse cursor glide over each icon, it will give you a brief description afte a second or two, The one you are looking for will say "safely remove hardware" or something to that effect. Click on it, if you have more than one device here, those options will pop up. Click on the one you intend to disconnect and wait a minute:you should be notified when it has been disconnected.
Hope this helps!
Dec 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What can i do?
Hi, I hope you have connected your nano to the PC thrught itunes. it's very usual to remove the USB devices from PC with safely remove hardware option at the right bottom of windows. in case of itunes they hace included the option as Eject in itunes which should be done to avoid data loss and proper disconnection of device from the PC. this is not a problem.
Oct 26, 2009 | Audio Players & Recorders
Removing my usb stick
"removing my usb stick" - This seems like a statement, not a question.
That said, the biggest problem people have removing the USB stick from a computer is that they fail to unmount the drive before removing it. In Windows this can be done by left clicking the "Safely Remove Hardware" icon in the task bar, clicking your device, and then waiting for it to tell you that it is ready. With Mac and Linux you just right-click and unmount the drive.
Either way, not doing this can wipe your USB drive or corrupt your files.
Sep 30, 2009 | Computers & Internet
Can't seem to stop the device to safely remove hardware
if you know it is done transfering the data you should be able to remove it safely even if that message pops up.
Jun 13, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
The device Generic volume cannot be stopped right now. Try stopping the device again later
why not try to use a separate program to safely remove the drive.
download here
what is it?
USB Safely Remove is a USB device manager. It saves time and extends user abilities on active work with flash-drives, portable drives, card readers and other gadgets.
post back and let us know.
Feb 09, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
The Safely Remove Hardware dialog box does not appear
not really, you may be able to select the option, if you right click on the drive in my computer, but they don't always disconnect the hardware anyway, so just remove it as lons as you know there is no activty
Aug 24, 2008 | Coby MPC895 MP3 Player
Disconnecting player while in MTP mode
It is not designed to show up as a Removable Disk in MTP mode, therefore it wont show up in the Safely Disconnect Menu.
If you are using Windows Media Player to transfer, as soon as the SYNC is complete, it says "ok to disconnect". You can disconnect without any problems.
If you are using Rhapsody, or the Best Buy Digital Music Store, you can right click on the device in the Sources Menu and select Disconnect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Then:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
56 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
