Question about Boating
1973 6hp Johnson- How much oil does it take for the lower unit, and what type of oil is recommended?
  • 677 Answers
It takes less than 1 litre.You buy it in 1 litre bottles.Go to any boat shop and ask for gearbox oil.There is 2 screws to remove and they have a washer on each.Replace them also.The oil is put into the lower hole untill it starts to come out the top hole.You then quicly put the screws in.The oil container comes with a taped nozzle to do this and its a squeeze bottle..Also a good time to take the prop off and check for fishing line etc. that can damage the seals and to also grease the prop shaft.Hope this helps
Posted on Sep 06, 2010
How do you service lower unit on a 1989 Johnson outboard motor?
What do you need to do? It is easy to open the two screws to drain lower unit gear lube but drain into a container and not on the ground. I have a pump that I use to replace the lower unit lube. Pump hooks up to quart or larger size lube supply. I have seen U TUBE videos if you need instructions.
Nov 01, 2017 | Johnson Boating
1966 Johnson outboard 9.5hp. Lower unit oil leaking past prop. What parts do I need and how to install it.
drive shaft oil seal and possible shaft
take it to an outboard service shop as it may require special tools for the job
Aug 01, 2017 | Johnson Boating
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Have just bought a 1993 90hp v4 johnson and would like to know what type of oil to use in the oil resevior
Any tcw3 two stroke oil . I am a marine mechanic and I would recommend disconnecting the vro which is the oil injection. Just disconnect the oil line and then mix the oil in the gas 50 to 1. The vro is known for going out and taking your motor with it
Dec 03, 2012 | Boating
How do I check the oil level in the lower unit of a 70 hp Johnson outboard?
remove the bottom drain screw first then place a tube of the proper lower unit oil in it. then remove the top screw and gently squeeze the tube of oil and when full it will slowly come out the top drain hole. when it does replace the lower plug first then the top plug second. make sure the seals are in good shape and plan on changing the oil in the lower unit yearly for proper maintainence. make sure you buy oil designed for your particular type of motor. good luck.
May 29, 2010 | Boating
I need lower unit lube capacity for johnson 200 horse power out board
there is none listed . you fill them from the bottom plug with the top plug removed . when lube comes out the top hole it's full . put top screw back in which will not let oil out the bottom then put in the lower plug
Apr 10, 2010 | Boating
How to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Dec 30, 2009 | Boating
9.9 johnson want open up
Is it a reconditioned lower unit?
What sort of oil did you put in the lower unit?
Sounds like there is some drag in the lower unit causing the engine to bog down. It will work fine on a stand in neautral however.
How does it go in reverse on the lake? Can you get full throttle?
Jul 24, 2009 | Boating
Lower unit oil change on 1995 40 hp johnson
Howdy, John here, I have a 40hp 1995 Johnson, of the 4 screws, two are screws and two are plugs, the top one is the vent and the bottom one is drain and fill. Oil is forced in from the bottom and out the top to prevent air pockets.
After filling, install the top plug first, then remove the filling device and install the plug.
You can get an online(pdf) service manual subscription from www.seloconline.com
Jan 02, 2009 | Sport & Outdoor - Others
Boating Logo
274 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
