Question about Dryers
Ge electric dryer
I have a 2002 ge electric dryer that is squeeking REALLY bad. my husband replaced the belt, but it still squeeks. do you think we need to replace the barings? if so, what is a good web-site where it will show us how to do that? thanks!
  • jen_benner12 Mar 03, 2009
    I have the same problem with our 2002 GE electric dryer. Are the parts very expensive to replace.
  • Anonymous Mar 17, 2014
    i can't figure out how to get to the motor
    President:
  • Dryers Master
  • 2,651 Answers
Most likely source of sqeak fornt front glides or rear bearing, the front glides can be seen be removing the front panel, 4 plastic strips the tub rests on and spins across, they will look worn or even missing if thats the casse( they simply twist on) as far as the rear bearing ,,a.k.a. "top hat" , for it looks liek a top hat, the drum is simply pulled foward and out of rear post and the bearing can be reinstalled without even removeing the belt form the pulley
Posted on May 13, 2008
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
Taking a ge dryer apart to replace worn belt. the dryer works fine with light load but squeeks with medium to heavy load. drying time is fine.
you will need to replace the drum glides near the front of the drum,just behind the door,which will require you to remove the front panel to access the glide unit,there is a gold and a green glide,you will need to get the right one after disassembly
Jan 12, 2010 | GE DWSR483EBWW Electric Dryer
Elec. dryer squeeks...squeeks...squeeks...replaced belt, did not improve. Could it be the plastic drum slides, I only say this because they look really worn?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 10, 2009 | GE Profile Wizard DPSE592EAWW Electric...
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
When I turn on the dryer it makes a sqealing noise. Belts seem ok.
there are wheels that hold the drum in place they have berrings that tend to go bad i would replace them it should fix the squeek. also you can put some bar soap aon the beld to quite the squeek if it is not the holding wheels
Jul 21, 2009 | Whirlpool LER5636P Electric Dryer
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
167 people viewed this question
Top Dryers Experts
