Question about General Electric WBVH5200J Front Load Washer
TIMER STAYS ON 3.8 AND WASHER WON'T START HAVE UNPLUGGED AND PRESSED POWER BUTTON TO RESET ALL LIGHTS COME ON BUT WASHER WILL NOT START
  • deehodges Sep 06, 2010
    thank you...i'm going to search for the part online and the schematics to repair it
  • 11,896 Answers
Sounds like you have a faulty timer. It is possible the control board is bad, but sounds more like a timer problem.
Posted on Sep 05, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    Try daysappliance or partselect . com. They should have it.
Hotpoint aquarius program won't start
Try this. Unplug unit. While unplugged, hold in power button for about 10 seconds. Release plug back in. See if that has reset the control module. Works on some other makes. Can't hurt to try.
Mar 10, 2015 | Hotpoint WML540P 60cm Washer Front...
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
CND UV box beeps and turns off
the bulb times needs to be reset. push and hold the reset button until it beeps 3 times and displays 100 and you should be good to go.
Nov 22, 2011 | Creative Nail Design Pro Dial U.v Lamp Cnd...
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
is any thing on or working check to make sure door is latched
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Apr 15, 2007 | Frigidaire GLTF1240A Front Load Washer
General Electric WBVH5200J Front Load Washer Logo
Top General Washing Machines Experts
Oloyede Monsuru
geapptech
Are you a General Washing Machine Expert? Answer questions, earn points and help others
