Question about Tappan TEF242 Electric Kitchen Range
The range does not heat up. what is the most common reason for this?
  • Tappan Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 07, 2010
Maytag microwave mmv4184AAQ not heating
The common reasons are a shorted diode many use, the inverter board used for control and power, and the Magnetron which does the work
Dec 07, 2012 | Maytag Appliances Over-the-Range Microwave...
Crosley CEDS774JQ0 electric dryer. It wasn't drying well so I pulled the vent line and cleaned it out well, ran the brush down the filter area too. Good venting now. But no heat, none at all. Ideas?
Do not know the model in particular, but by "not drying well" you mean not much heat, and then after cleaning there was no heat---would suspect the heating element (220Volts divides to 110 to make lower heat, like on a range burner) or operating on only 110v. The jostling could have completed the burn-out point of the heating element. Could check for continuity of the element (unplugged) using VOM (volt ohm) meter or flashlight bulb, wire, and battery--bulb metal to one end and wire to bulb tip and other end of wire to other end of element. If careful and safe access could check that voltage to heating unit is in fact 220 volts with VOM set to AC 600v setting (greater than 220v) unless automatic range setting VOM. (or check voltage to element first).
Also, remember when finished to check that vent hose is to inner vent pipe, not just to cabinet; lint build up in cabinet is a common reason for heating elements to burn out.
Aug 08, 2009 | Dryers
Rangetop works, Broiler works, oven does not.Electrics seem fine; Should I check the solenoid valve first?
For future reference, you need to explain whether this is a GAS or ELECTRIC range. It does make a difference in diagnosing the problem you have.
If this is a GAS range, the problem is more than likely a faulty igniter on the bake manifold. Since the bake feature gets used more often, it is common for the igniter to wear out faster. The following link explains how the igniters work and instructions on replacing one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If this is an ELECTRIC range, the problem is more than likely a defective heating element for the bake feature. The same reason applies. Since the bake feature gets used more frequently, the elements wear out much quicker. The next link explains how to replace a heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
I don't know what solenoid you are asking about, but if this is in reference to a gas safety valve or regulator, you would have similar problems with the broil functions if the there was a gas flow problem. Since MOST ranges are fed from a common regulator, gas flow to all the features would be impacted.
Replacement parts can be purchased on line at appliancepartspros.com, pcappliancerepair.com, searspartsdirect.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop around for the best price. If you have any questions, please let me know. I hope this helps you.
May 19, 2009 | Kitchen Ranges
Erratic/slow heating
Hi, It sounds like you need to change the on=ven ignitor. Even tho it glows, it is weak and will not open the gas valve consistantly. It is a very common problem. Please let me know if I can assist you with part# or how to replace the part.
Thanks
Vic
May 17, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Turned on self clean on my GE Spectra JBP24B0B4WH Range
Hello Cliff Hendershot,
One USA manual ... said turn off power for 10 minutes
(sounds reasonable after looking up cost of control board)...
USA websites are not responding to your number.
Closest I could get was to a $78 (us dollar) control panel
>> ((IMPORTANT PART ... has a video that shows repair))
http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
I could NOT get a good READ on your JBP24... page 8
So I attached a JBP19 (below)... Page 12.
The most COMMON reason to FAIL after a cleaning cycle
is your OVEN CONTROL is "off normal"
(You still do not have your MANUAL MODE restored).
Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
Check your "oven controls"
else
Oven elements do break during routine use...
Check both roast & bake elements for continuity.
GE JBP19 Owner Manual Usingthe Oven
Carnac the Magnificent
Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
99 plymoth voyager wouldnt shut off with key then white smoke
There could be several reasons, here's a list of the most common things it could be.
  1. check the timing
  2. idle speed is to high
  3. incorrect spark plug heat range
  4. intake air vacuum leak
  5. valves sticking
  6. leaky fuel injectors
Mar 12, 2009 | 1999 Plymouth Voyager
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Oven will light but won't heat up
sounds like an isue with your bake ignitor, common issue with all gas ranges, repace teignitopr and youll be fine
Nov 25, 2008 | Frigidaire FGF316 Gas Kitchen Range
Everything works except bake
Larry, you probably need a new ignitor, a common failure. If you want to be absolutley sure you would have to do some checks on the main board. On the board you would need to check the voltage between terminal marked BA and terminal marked N (neutral) when in the bake mode. Should have 120V. If you have this, the ignitor is a pretty sure shot....Catriver...post back.
Oct 16, 2006 | GE Profile JGSP48 Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
124 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
