Question about Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
Engine quits running at full throttle and hot
  • 44 Answers
Sounds like coil but check oil
Posted on Sep 09, 2010
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
My 1998 Chevrolet Malibu is giving me trouble. It runs smoothly most of the time but often the engine will quit running while decelerating suddenly for a sharp turn of a full stop. How do I fix.
Save yourself some money , Take it to a ASE repair shop an have it diagnosed ! don't just replace parts have it hooked up to a diagnostic scan tool !
Jun 15, 2015 | 1998 Chevrolet Malibu
Engine quits at full throttle, no warning. Won't start for awhile after
What make and model of engine is it? Inboard, outboard? Petrol, diesel? How long does it run before it cuts out? Does it get hot or does it stop while still cold? It sounds like a petrol supply problem, but the cause could be electric or fuel. A fuel restriction such as clogged filter could do it, but an electrical fault could also do it as the temperature increases. I tend to think it's more likely fuel though but don't have enough info. I'll look out for your reply
Jul 30, 2013 | Boating
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
1992 Cadilla Seville will not restart after it has run for about an hour. Must leave for several hours before it will restart
sounds like a temparature sensor problem - mixture is too rich to start hot. try starting it with full throttle - if it will start after 15 seconds of full throttle and cranking the temp sensor is definitely at fault - you wont flood the engine doing this only give more air to the engine.
Jan 24, 2010 | 1992 Cadillac Seville
Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Dec 23, 2009 | Garden
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Engine dies after quick shifting and long full throttle
try to adjust your chain and check your sproket for damage.
Aug 02, 2009 | 2001 kawasaki KMX 125
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
170 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
