Question about LG Refrigerators
My LG GR-151 SSF Fridge is getting too cold and freezing the food, I have noticed there is a clear plastic pipe on the inside that is hanging down and not connected to anything, I'm sure this should be attached to something.
HVACRH20
  • 237 Answers
SOURCE: Fridge does get cold
Sounds like the motor starter/capacitor may be faulty. How long does the compressor run for? Do you hear a clicking every few minutes from the compressor? If a power surge fried the defrost timer that too could give similar results.
Posted on Dec 20, 2006
SOURCE: My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Posted on Aug 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
SOURCE: Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Posted on Jun 19, 2010
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
What has caused my water inlet pipe feeding the ice making machine to freeze?
It seems there is some blockage in copper tubes ( capillary)
Need to flush internally and then refill refrigerant
Jul 20, 2016 | LG Refrigerators
Express freeze
Try and access the coils and see if they are dirty. Cleaning them can sometimes clear up the problem. Dirt works like an insulator and makes the fridge run more than it should so it gets very cold.
Jan 23, 2014 | LG Refrigerators
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
My fridge is freezing all my food
temp to high,but the most likly culpet is a blocked outlet pipe at the rear of fridge ,it drains water and should have a plunger/plug.to clean the hole get a plastic ty or a pipe type cleaner and push up and down until clear.adrian
Mar 15, 2011 | Dometic Refrigerators
Unplug fridge.
Good Luck
Jun 12, 2010 | Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Drippy LG Fridge
should be tray under freezer
Aug 17, 2009 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Refrigerators Logo
250 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
