Question about Maytag 30 in. CSE9000 Electric Cooktop
I need a wiring diagram for the 6 wires that are in the flex that feeds the unit
    Problem Solver:
  • 5 Answers
If it's like mine white to neutral, bare to ground, red and yellow to the red, black and blue to the black
Posted on May 07, 2011
Wiring diagram
A wiring diagram is a simple visual representation of the physical connections and physical layout of an electrical system or circuit. It shows how the electrical wires are interconnected and can also show where fixtures and components may be connected to the system. Use wiring diagrams to assist in building or manufacturing the circuit or electronic device. They are also useful for making repairs. DIY enthusiasts use wiring diagrams but they are also common in home building and auto repair. For example, a home builder will want to confirm the physical location of electrical outlets and light fixtures using a wiring diagram to avoid costly mistakes and building code violations.
http://resumeplus.us
Sep 01, 2016 | Cooktops
Where can I get a wiring diagram for whirlpool speed top 2600 electric cooktop
Sometimes if you call the manufacturer of an appliance and have your model number ready, they will email you an diagram or mail it to you. I would not tell them what you are planning on doing, simply because of them not recommending doing this they may not give you what you need. Just tell them you need a diagram thats all. I've done this in the past and it was free, just depends on the company you are dealing with. Hope this helps, good luck.
Feb 11, 2012 | Cooktops
Maytag cse9000ade cooktop. Does anyone have
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
Kelly
May 03, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Wiring a jec9536bdb cooktop
you need a three wire or two as long as you have the two hots and ground. dont skimp on wire size though. hope this helps
Nov 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Elecrical hook-up for cooktop
Based on your description...it appears the Viking unit may NOT comply with UL and the NEC....but implies that some local Codes may permit the suggested connection...and it may indeed be permitted - if the unit actually draws straight 240 and does not require a neutral for 120 volts (some cooktops do need the neutral for 120 volt control switches...such as your Jennair). Code now requires that new 120/240 units that require the neutral (your Viking unit states that it does not) be a 4 wire assmebly....and your unit MAY be an exception to this requirement.
Under those conditions...then it more then likely CAN be connected as you (and Viking) suggest - black to black, red to red,green to white...and insure that the junction box is indeed well grounded to the supply bare ground wire - so that the metal flex will serve as a supplemental ground to the cook-top.The only other consideration will then be - IS the exisiting wire size and breaker that used to supply the Jennair correct for the new unit..? And if so - then you should be all set with your suggested hook-up...but without electrical nameplate data for both units for comparison...I have no way to determine that....both companies make several different models with different power supply requirements.
If the electrical data is compatible between the two units...then you should be all set as suggested - without having to rewire the cooktop.
Hope this helps...please follow-up if you need more details or have new information for me concerning this cooktop.
Feb 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
124 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
