Question about American Standard Hampton 7225.733.002 Chrome Three-Handle Bath/Shower Fauc...
Installed bath 3 handle unit. hot handle is stiff and hard to turn, shower diverter is loose. How can I loosen the one and tighten the other? I'm sure it's probably the same adjustment
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
The handle adapters can be tightened by turning them clockwise and loosened by turning them counterclockwise. If the faucet manifold may need to be lined up parallel behind the wall and moved forward as well. Here is the parts breakdown for your faucet,
Posted on Sep 06, 2010
There are two shower handles, one to divert to the shower head and another to divert to the rain head. one of these handles has loosened and falls away from the neck.
Look for an Allen screw hole the Allen is loose or has stripped and needs to be changed out. Sometimes if they are over righted they strip on bottom, also make sure it hasn't backed out completely. Some older handled have a square piece that the handle goes over then the screw is tightened under a plastic cap tha has hot H or cold C on cover.
Aug 29, 2015 | Grohe Home
Can't take a bath!
The diverter can become clogged with mineral deposits. The handle will have to be removed to gain access to the diverter. The diverter can then be disassembled as necessary to determine what needs to be done to free it up.
Jan 17, 2014 | Home
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Feb 02, 2011 | Perrin and Rowe Rohl Bath U-5386 ; U 5386...
When I pour a bath the shower comes on as well as the spout but only when the handle is turned to the middle position (warm). Turned all the way to hot or all the way to cold it seems o.k. I have a Moen...
I've never heard of this before. Nornmaly its shower or bath that is controlled by diverter on spout. All I can say is mabe try installing a new cartidge and see.
Oct 03, 2009 | Plumbing
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
American Standard Hampton 7225.733.002 Chrome Three-Handle Bath/Shower Fauc... Logo
315 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
