Question about Aiptek MPVR Digital Camera
How do i fix a "card protect" warning message
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
how do i fix a
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 06, 2010
How do i dispose of old movie film
Garbage bin? Sorry I could not help, making this joke. But I think I know what you mean. The old movie film is still in your camera?
On a memory card? If it is the only movie, it would be a good idea to format the memory card. This not only will wipe the movie, but cleans up the card complete.
If I had known more details, perhaps I could have told you what menu item you should goto, for wiping picture, or movie. Or for formatting.
I also could warn you, if certain messages came on the screen, like Picture is protected or card is protected.
Nov 21, 2013 | Cameras
How do I fix the write protect message error?
Open your camera to find the memory card/sd card inside. it may have a small tab on it you can click to protect the card. Make sure it is not set to protected.
If it is an sd card it will look like a very small white tab.
Mar 02, 2011 | Olympus Stylus 720 SW Digital Camera
Protected Card warning won't let me shoot pictures, can't find info how to delete or fix this.
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Jan 28, 2010 | Fuji Cameras
I continue to get this error message on my HP A612.
first check the card to make sure it isn't write protected, if it isn't write protected, put the card into a camera and the camera should fix it
REF:
http://h10032.www1.hp.com/ctg/Manual/c00701123.pdf
Dec 25, 2009 | HP Photosmart A612 InkJet Printer
Memory card locked on a canonpowershot sx10is how to fix it will not let me in the format program
Take the card out and check to see if it has a switch, very small, that is in the locked position, this will stop you from formatting or even deleting things from the card
Jul 26, 2009 | Canon PowerShot SX10 IS Digital Camera
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
My camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Feb 07, 2009 | Olympus Cameras
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Aiptek MPVR Digital Camera Logo
32 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Greg Cann
Greg Cann
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
