Question about Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking
We recently moved and our bravetti Platinum Pro convection oven is not working. We keep getting a code of E-1 and cannot set temperatures. What can we do to fix this?
  • 3,083 Answers
I would suspect that wire connectors to a switch has vibrates slightly loose. Take the unit apart, and clean and tighten any wire connectors, and elements if you can get at them. Since you moved and had the problem, it's most likely a physical connection not quite making contact.
Couldn't find anything on the error code on the net, so refer to the manual. It might help.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 06, 2010
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Using rotisserie in Bravetti Platinum Pro Toaster Oven Broiler
no the bottom element stays off when rotissereie is used . if it was on the liquid that drips from the cooking meat would smoke or might even start a flash fire ....... if this answer helped please rate a3 or 4 stars this high rateing will help keep me in the paid answer department thank you
Apr 01, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Hot plate not working
Check the non working plate element for continuity - if open replace it. Otherwise the switch is bogus.
Sep 04, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Nov 30, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Time control knob for bravetti platinum pro convection oven
Thanks for allowing me to help you. The replacement knob is available from the following link:
www.euro-pro.com/europro/productdetail.aspx?pid=1D76CC6A-4A86-4D6B-8120-7DB204F16DF4(Euro-Pro+Base+Catalog)
You can also get a user's manual if you need one.
If you found my assistance valuable, please give me an appropriate rating. Thanks for using FixYa!
Oct 19, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Convection mode
I would assume that these ovens have a faulty fan motor mount or it may just be a bad design. I would go with a different make or model.
Apr 26, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking Logo
106 people viewed this question
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
