Question about Kenmore Oasis HE 27082 Top Load Washer
Hi I have a kenmore oasis top loading washing machine and it keeps giving me an error code F1 and in the manual that says to consult a maitanence person, but that is going to take up to 4 weeks. What's wrong with my washer? My serial code is CU0870312 thanks
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 15, 2010
Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My oasis he top load washer is now flashing F1 error code. I tried calling sears and all i got was "your warranty has expired, we can send a technician out but can't help you over the phone. any idea what...
The Kenmore Oasis and Whirlpool Cabrio washers are basically the same machine.
Following is the Whirlpool service manual for the Cabrio.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F 1 points to a primary control failure.
Oct 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE shuts off during wash cycle and gives F1 error
F1 error means the main control computer board. see other posts in this section as there are many who are complaining about the same problem. buying the new board (revised) will solve the F1 problem, but other problems will soon crop up on this POS washer. if you have the chance to return it to sears, return it immediately!!!!
Mar 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
