Question about Whirlpool 18 in. ADP530 Free-standing Dishwasher
My dishwasher Whirlpool ADP 533-1, no heating the water. The temperature sensor NTC is OK. The relay in the electonic card is OK, but their coil no receive 12 VOLTs DC. I want de manuals of ADP 533-1
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 07, 2010
Flashing light 6 times, whirlpool dishwasher ADP4501
I had the same problem with a Whirlpool ADP 6515, led flashes 6 times, pause and repeat.
Open the door, remove the 2 screws that hold the control panel (1 top left, 1 top right). Gently lift the control panel up and away from the door to reveal the wiring, controllers etc. My controller was a Flextronics UCB-IC-EBL-P7-M3-HE1. Look at the connectors, one of them is marked on the controller as NTC and has 2 blue wires, push down on the white plastic tab below it and disconnect it (pull it horizontally away from the controller)..
I used a multimeter on 200k range and measured the resistance by probing those 2 blue wires and the NTC temperature sensor measured about 50k ohms +/- 5k depending on the room temperature. And that is correct for that NTC. (I knew the NTC was good as I had removed it from underneath the machine previously and measured the resistance whilst holding it under the hot tap as it went from cold water to hot. It's a Negative Temperature Coefficient sensor so the resistance reduces as it gets hotter).
So problem was definitely not that.
Solution was simple, on the connector itself, just use a very small flat bladed watchmakers type screwdriver to clean the pin contact faces and then gently pinch the pins of each wire closer together so that they bites tighter onto the controller.when you reconnect it.
Refit the control panel and problem solved.
Conclusion; the contact resistance of the connector to the controller added to the total resistance of the NTC and made the dishwasher think that the water was below the safe activation of the motor cycle, e.g. it thought the water was iced up.
Job done !
Apr 25, 2012 | Whirlpool Dishwashers
My washer starts lets shuts down with a code of f5
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
•Check the Water Temperature Sensor, Heating Element and Element Relay
•Check connections to the Sensor, Heating Element and Relay
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Get error message F5 about 3 minutes into the cycle, have to reset multiple times to override
F-5 Water temp sensor failure
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
I have a service manual and some repair photos HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code error F05
If this is a Whirlpool model the FO5 error code means:
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
F/H
F/02
Hope this sheds some light on your problem
kcomp1863
Jan 20, 2011 | Washing Machines
F05
Guessing your talking about a whirlpool below is the meaning and the corrective actionsneeded.
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
If you have anymore questions please feel free to ask, Rich.
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Error message "F5"?
F5 is a Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. If you are savvy enough to troubleshoot yourself, you can check the Water Temperature Sensor, Heating Element and Element Relay. You should also check connections to the Sensor, Heating Element and Relay. As far as servicing goes, Sears and Whirlpool have service contracts on these appliances as the Kenmore Elite and Whirlpool Duet are the same machine made by Whirlpool. I hope this helps you.
Sep 19, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool 18 in. ADP530 Free-standing Dishwasher Logo
620 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
