Question about Olympus P 400 Thermal Printer
P400 - A fine white line is being printed to the bottom of my photos. How to fix eliminate?
White Lines over Black Colour?
MAKE PRINT ALIGNMENT
IF THE PROBLEM PRESENTS
FALLOW LINK
PIXMA MG5250
May 07, 2014 | Canon MG5250 Printer
Problem printing photos accurately.
I fixed the problem by eliminating possibilities. The problem is with the default setting on iPhoto which I use to edit photos before copying to a USB then printing. I need to change the default setting constraint to 4x6. The problem is not with the camera. Camera is great! Thanks.
Oct 14, 2009 | Pentax Optio E60 Digital Camera
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Cropping Photos
sure..check your scaling settings in photoshop, which is based on the size of the paper you're using.
Feb 12, 2008 | Olympus P 400 Thermal Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Horizontal lines
do a nozzle check, or printer utility check on the printer and see if this helps.
Jun 08, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Olympus P 400 Thermal Printer Logo
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
