The power will turn it on buit not off and the channel button will not turn the channel
  • 456 Answers
When you turn it on, are you using the remote control or the power button on the side of the unit?
When pressing any buttons on the unit, be it the power from the channel selectors, you should hear a 'click' from the actual button on the printed circuit board inside the unit.
If you are not hearing this 'click' the plastic mounts holding the printed circuit board in place may have become dislodged from its position. You can rectify this but it will involve removing the back of the unit to access where you need to get too.
If you are hearing this 'click' and still nothing is happening, it's possible the buttons have become faulty and you may need to either replace the buttons or the entire printed circuit board that holds the buttons.
I hope this helps. Good luck.
Posted on Sep 05, 2010
How can i fix the blown speaker
If it has headphone jack, try to see if you get both channel OK. I would use the powered PC speakers attach to the Audio Line out RCA jacks than the cheap buit-in speakers, just make sure that you set the audio set up for the Audio Line out to be variable so you can use the remote to adjust the volume, and just set the PC volme to about mid point instead.
Nov 11, 2009 | Protron PLTV-32 Television
I have a few months old Toshiba Satellite M300
There is a button that activate and deactivate the keypad check if when you clean the keypad you touch a button by mistake that deactivate the mouse and click it again.
Aug 21, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
Rcr311w need help and advice on programming
WHAT BRAND OF TV ARE YOU TRYING TO PROGRAM
Jun 03, 2009 | RCA Universal Remote Control
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Aug 13, 2008 | Hitachi 42HDT52 42 in. Plasma HDTV
Wireless
welcome to fixya
what OS are you running and are you sure the laptop came with wireless buit in?
if you have vista goto connect to on the lap top and should bring up wireless options if there is none the more then likely you have no buit in wireless
but you can try to goto device mamger and see if you can find it in the list if yes see if you can update drivers ...
hope this helps you out have a good day
Jul 27, 2008 | Compaq Presario M2000 Notebook
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
