Question about Toshiba Computers & Internet
Toshiba lap top will not start windows goes repeatally back to boot options all will not work counts down from 30
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Tap F8 from boot and then select last known good settings that worked from the list.
Posted on Sep 05, 2010
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Hello.
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
I dont know how to use my recovery disk for my toshiba lap top
Here are the steps on how to install operating system using the recovery disc
- power on the computer and insert the disc - once the disc is inserted, turn off the computer - press the power button then after 2 seconds tap F12 repeatedly - select the cd/dvd option or ODD (optical disc drive) use the up and down arrow keys - press enter - once you see "press any key to boot from CD" press enter right away
it will show " Loading Windows"
- then after the next phase will be set of on screen instructions, you just have to select the right option.
Jul 09, 2011 | Computers & Internet
Windows is failing to start. Giving me option to launch startup repair or start windows normally but not doing anything when I choose either option, just counting down from 30 then coming back to same...
You may have to do a system reformat to reinstall windows on your computer. Put your boot disk into the disk drive on your computer, and restart it. As the computer turns on, press F12 to access the boot menu.
May 02, 2011 | ASUS Computers & Internet
MY lap top qosmio G45-AV680 idoesnt let me operate the windows vista it turns to a black screem but the mouse still there
If you wait longer after boot up windows will eventually recognize the proper card drivers and install them. It is a good sign that you are seeing the mouse. Reboot and wait for at least 30 minutes and repeat process until it finds the proper driver. it should take the most 3-4 times
Oct 06, 2009 | Toshiba Qosmio G45-AV680 Notebook PC
Gateway desktop xp starts then flashes blue screen for split seco
Sometimes they make the recovery disk with windows on it, but not the programs that start windows during the boot up phase. One of the three main files that boots into windows is corrputed or your Master Boot Record is missing. There are two options you can try without the OS disc so lets see if one of those will work: 1) boot up and press F8 to enter safe mode. Once in safe mode sometimes you can also get into window because just the minimum of the program is loaded. F8 Safe Mode>in windows>click start>accesories>system tools>system restore. It will allow you to restore your computer to a prior date before you have problems. 2)if that don;'t work then F8 safe mode and while in safe mode choose Last Known Configuration. Kinda works the same way as restoe but you don't have to be in windows to do it. If those don't work then get your hands on a windows xp disc, anyone's will do, don't have to be yours. Let me know how it goes.
Rate this solution. You can also find out about this at support.microsoft.com>help and support>type in Windows XP boot disk in the search engine.If those don't work let me know and we'll move on to phase II.
Mar 14, 2009 | Gateway Computers & Internet
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
Possible motherboard issue???
I suggest you should repair your OS. Just insert your winxp cd installer and boot from cd.
there is Rapir option at windows installer option. just repair it and you will get your windows work again in approx. 30 minutes :D
br
Aug 06, 2008 | Gigabyte GA-K8NXP-SLI Motherboard
My laptop won't start up and i can't use the recovery media to sort it out.
its sounds either your windows has been currepted or you have some missing driver/software wich cause re-start.
  • Try to boot in safe mode.
  • Start pressing F8 after making on your lap til the boot option menu appears.
  • Select Safe Mode and press enter.
  • If your lap boots well then, goto Start -> Run and type msconfig in the commad box and press enter key.
  • In System Configuration Utility click on Services tab and click Hide All Microsoft Services after that click on disable all. Then press Ok and reboot your lap normally. After do same as above and enable one by one service to get which cause problem.
If it even does not boot in safe mode, then i think you should re-install windows.
Thanks & good luck
Iqbal
May 18, 2008 | Toshiba Satellite A205-S4777 Notebook
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
