Cannot send fax-image on fax send report is off.
    Guru:
  • 731 Answers
May i know the Printer Model?
Posted on Sep 05, 2010
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
HOW TO PRINT CONFIRMATION PAGE
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Image on fax send report is set to off
you did not mention your HP Printer model, however if you are getting the message " Image on fax send report is off " you can try this setting on your Printer.
Press the Setup button on the printer front panel ( Ranch like symbol )
Scroll using the down arrow ( or arrow keys ) till you find Print Report option - Press OK
Scroll till you find Image of Fax Send Report - Press OK
Turn if off/on using the arrow key - Press OK
The Issue is resolved.
Regards,
Ron
Feb 24, 2011 | Office Equipment & Supplies
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
-OR-
Press Menu/Set, 2, 4, 2.
Note
is a transmission error, with ERROR in the
RESULT column.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Confirmation print out
Your wanting what Brother calls a Transmission Verification
Report:
RESULT column.
a Press Menu, 2, 4, 1.
b Press a or b to choose Off+Image,
Press OK.
c Press Stop/Exit.
Nov 11, 2007 | Brother MFC 240C All-In-One InkJet Printer
13 people viewed this question
jasbo
jasbo
